General Discussion
EULA Acceptance error post FOS upgrade from 8.2.2d4 → 9.0.1x*
sanstorage
switch model Connectrix DS-6630B
Hi All,
We recently encountered EULA acceptance error during our upgrade on below path.
Planned upgrade path is 8.2.2d4 → 9.0.1x* → TruFOS Install → 9.1.1x* → 9.2.0x → 9.2.2b.
1)upgrade from 8.2.2d4 → 9.0.1x* - was completed through CLI, how ever unable to login console post reboot. We ended up with "EULA ACCECPTANCE" error as below
l11-ds@server1 $ ssh [email protected](switchip)
[email protected] password:
Failed to process EULA acceptance, auto-logout
Connection to x.x.x.x closed.
Previously before the upgrade switch has IC error
errdump:
2026/05/14-07:04:56, [EM-1029], 5492, CHASSIS, WARNING, DS_6630B, Switch, a problem occurred accessing a device on the I2C bus (-4). Operational status (10) not changed, access is being retried.
2026/05/14-07:05:01, [EM-1029], 5493, CHASSIS, WARNING, DS_6630B, PS 1, a problem occurred accessing a device on the I2C bus (-4). Operational status (10) not changed, access is being retried.
2026/05/14-07:05:05, [EM-1029], 5494, CHASSIS, WARNING, DS_6630B, PS 2, a problem occurred accessing a device on the I2C bus (-4). Operational status (10) not changed, access is being retried.
The switch Sensors and Temperature status is stuck in “Unknown” due to I2C bus warning:
tempshow :
Sensor State Centigrade Fahrenheit
ID
1 Unknown
2 Unknown
3 Unknown
4 Unknown
5 Unknown
6 Unknown
7 Unknown
8 Unknown
9 Unknown
10 Unknown
sensorshow :
sensor 1: (Temperature) is Unknown
sensor 2: (Temperature) is Unknown
sensor 3: (Temperature) is Unknown
sensor 4: (Temperature) is Unknown
sensor 5: (Temperature) is Unknown
sensor 6: (Temperature) is Unknown
sensor 7: (Temperature) is Unknown
sensor 8: (Temperature) is Unknown
sensor 9: (Temperature) is Unknown
sensor 10: (Temperature) is Unknown
sensor 11: (Fan ) is Ok,speed is 6535 RPM
If any article or if any one has similar issue please let know with root cause o
sensor 12: (Fan ) is Ok,speed is 6535 RPM
sensor 13: (Fan ) is Ok,speed is 6535 RPM
sensor 14: (Power Supply) is Ok
sensor 15: (Power Supply) is Ok
1 REPLY 1
sanstorage
Hi All,
We would like to share, The error  EM-1049 on IC bus was the reason  for the issue,
Resolution was -  We did power off the switch and  with removing the SFP of each port and reinsert the SFP.  Post power on and  enable the switch, we are able to login the console. Error EM-1049 was not reflecting and FRU was healthy .
Also we validated  and found faulty SFP  which was replaced later.
We have completed with upgrade without any issues.
