General Discussion
Executing commands when logging on CLI
GrumpyOldMen
Silly question probably... but is there a way to configure certain parameters to a different value then the default. I would like to have a "row 0" when logging in and not the default... Also valid for other settings like "set -prompt-timestamp inline"...
1 ACCEPTED SOLUTION
GidonMarcus
Hi
i don't think there's an ONTAP way, seems that it's exists in KiTTy:
https://superuser.com/questions/587629/how-to-run-a-remote-command-in-putty-after-login-keep-the-shell-running
Gidi
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
3 REPLIES 3
GidonMarcus
Hi
Gidi
donpaul0110
I was facing a similar issue, you solution worked, thanks for posting.
DanielMoll
I wonder if there is still no ontap-builtin solution for that... storing default settings like "rows 0" or "set -prompt-timestamp inline"...
cheers
