General Discussion
NetApp Harvest Failed to normalize unit
raph025
Hello All,
In order to be able to solve problems of data transfer with Dataontap 8.2.5, I installed a new grafana.
I have the latest versions of graphite and Grafana 5.2.4 and NetApp Manager 1.4.1.
ISSUE :
Under grafana I have feedback information but my logs go back many warnings like :
[2018-09-25 10:52:05] [WARNING] Failed to normalize unit val=[257067423] unit=[wafl_block]
[2018-09-25 10:52:05] [WARNING] Failed to normalize unit val=[823418] unit=[wafl_block]
[2018-09-25 10:53:04] [WARNING] Failed to normalize unit val=[66006654] unit=[wafl_block]
[2018-09-25 10:53:04] [WARNING] Failed to normalize unit val=[85081396] unit=[wafl_block]
[2018-09-25 10:53:04] [WARNING] Failed to normalize unit val=[823428] unit=[wafl_block]
[2018-09-25 10:53:04] [WARNING] Failed to normalize unit val=[257067425] unit=[wafl_block]
[2018-09-25 10:54:04] [WARNING] Failed to normalize unit val=[85081396] unit=[wafl_block]
I have arround 40 warning messages by Controler
Do you have an idea ?
Many thanks
Raphael.
1 ACCEPTED SOLUTION
yannb
It could be a bug indeed.
If you switch to mb_per_sec it should be fine.
You can also patch netapp-worker and add on line 2606 :
return ($val * 0.000003814697266) if ($connection{normalized_xfer} eq 'gb_per_sec');
5 REPLIES 5
yannb
Hi Raphael,
I looked at Harvest code and this message shouldn't happen, as "wafl_block" is a unit that should be taken care of.
Do you have "normalized_xfer" parameter in the harvest config file?
Are you absolutely sure this isn't an old version of Harvest?
raph025
Hi
Thanks you for your reply.
Yes, i have "normalized_xfer = gb_per_sec" in netapp-harvest.conf
Yes sure, this isn't an old version of Harvest .. 😞
Regards
yannb
raph025
Hi,
Thanks you very much !!
My issue is solved.
Regards
vachagan_gratian
For anyone else observing the same issue: I will post a patch that will fix this (as well as one other) bug in your Harvest installation. Hopefully by tomorrow 🙂
