General Discussion
Netapp Mini-usb Serial console issue Netapp 2712
asachuk
Hi  All!  I  need a help with mini-usb serial console cable.
I have Netapp  e 2712 with 6600series disk shelf.
Do you know what serial cable i shuld use  to get access to console?  I have tried  a lot of different variations
1)   Cisco  USB-to-Mini USB,  (WIN10, OSX, Linux Ubuntu)    nothing work.
Error   (unknown usb device needs more power than the port can supply)  after that usb port stuck.
2)USB - RS232  + NULL MODEM F/F  + RS232 -USB +  USB-to-Mini-USB-adapter.
and somo more few crazy  ideas.
I  have asked google a lot but i can`t find any informarion  about that adapter.
Could you please advice what type of cable should I use and   can i buy  that cable online?
Thank you for help.
6 REPLIES 6
SpindleNinja
The serial cable is usually resevered for support only,  why are you trying to connect to it?
The cable is just a standard DB9/mini-usb    I recall the 27xx series being 8-n-1-9600 connection settings for serial.
asachuk
Password was lost by old administrator.   Console cable was lost too.
I bought SARTORIUS YCC03-D09 MINI USB DATA CABLE WITH RS232 but still cant get access  to device.
I have tried  different speed  and key board combinations:
1) 8-n-1-9600 flow control  None
2)8-n-1-9600 flow control  Xon/Xoff
3)8-n-115200 flow control  None
4) 8-n-1-115200 flow control  Xon/Xoff
I didnt get comand promt  at putty window.
I didn press reset button because we have sensitive data on that storage
SpindleNinja
As far as I know it's just a normal serial cable DB9.    Have you tried another PC?
And have you opened a ticket with support for the PW recovery?
asachuk
 I  don`t have direct netapp support.   Don`t ask why, please.   I  got that system as is.
Cris_1972
Hi I have the same problem, have a storage and need to delete the data before we dispose of it.
Have you found the way to connect with USB console cable.
Thanks
asachuk
For the current storage I pressed the “reset”button on the controller and got admin privileged access then made all necessary changes.
