General Discussion
Unified Manager is not receiving subscribed EMS Events
kushneo
Hi,
We used to receive the subscribed EMS events into our Unified Manger event page, but we had to do a re-cabling of our Netapp disk shelfs lately & now we do not receive any System Manager subscribed EMS events into the Unified manager Event page, what could be the reason for this?  & How to fix this issue ?
Thanks
2 REPLIES 2
GidonMarcus
assuming you referring to Cdot. For some reason the script on OCUM that register the EMS alerts on the clusters is not so reliable.
run the command "event route show -destinations <OCUM Server>" to see if it's registered.
you can then set it manually with "event route  modify"
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
kushneo
Hi GidonMarcus
Yes this is Cdot & I have checked the connection by using the command event route show -destinations <OCUM Server> & it shows as my OCUM is registered & I have manually set EMS alerts thru the CLI but the issue is the same
