Legacy Product Discussions (RO)
unable to detect filers using performance advisor
netappnasadmin
Hello,
I am unable to detect my two filers using performance advisor checked all http & https connections but no luck.
i opened all the ports which are required for operations manager for filer to communicate.
can any one direct me on this ..?
3 REPLIES 3
BrendonHiggins
In performance manager it is just a case of going to setup and hosts.  Have you tried logging onto the performance manager server and pinging the filers?  Also try a Filerview session but it should work OK if the server can talk to the filer management port.
Hope this helps
Bren
netappnasadmin
Hello folks ,
I am getting the error when i ran dfm host diag filer_name
XML (https port 443)   Can't connect to host (err=5).   can any one point what is the issue.
Thanks
cdcoadmin
Hello,
I have the same error message today and found out that reconfigure of ssl solve the problem.
filer:
secureadmin setup ssl
