I recently picked up two fully loaded extra shelfs (DS14/MK2) and as I had a spare FAS250 head I decided I might as well test them out good.
However, both shelfs report:
slot 0: FC Host Adapter 0b (Dual-channel, QLogic 2312 rev. 2, 32-bit, L- port, <OFFLINE (hard)>)
I have two other of these shelfs that are fine and the FAS250 worked with those before I put them in production, its a spare 250 too. One shelf I'd suspect the shelf, but not both. Is there something internal to the shelfs that I might need to do? Both shelfs were used in a multi-shelf environment. And I've set them to ID 1 as well.
Is a terminator absoultely required for the FC channel to work? My two production system have no terminators and they work fine, but
I also read something about RoHS vs non-RoHS and for sure a copper based FC has to be terminated. Both extra shelves are non-RoHS.
Going into Maint 4a always gives no disks found.
Other commands:
*> disk show -v
Warning: Software-based disk ownership is not currently being used on this system.
Local System ID: XXXXXXXXX
disk show: No disks attached to system.
On boot up:
NetApp Release 7.3.2: Thu Oct 15 04:24:11 PDT 2009
Copyright (c) 1992-2009 NetApp.
Starting boot on Wed Dec 31 23:59:58 GMT 1969
Thu Jan 1 00:00:27 GMT [nvram.battery.state:info]: The NVRAM battery is current
ly ON.
This boot is of OS version: NetApp Release 7.3.2.
The last time this filer booted, it used OS version: <unknown>.
The WAFL/RAID versions of the previously booted OS are unknown.
If you choose a boot option other than Maintenance mode or
Initialize disks, the file system of your filer might be upgraded
to a new version of the OS.
If you do not want to risk having your file system upgraded, choose
Maintenance mode or reboot using the correct OS version.
(1) Normal boot.
(2) Boot without /etc/rc.
(3) Change password.
(4) Initialize all disks.
(4a) Same as option 4, but create a flexible root volume.
(5) Maintenance mode boot.
Selection (1-5)? 4a
NVLOG: UNKNOWN nvram magic value (0x1be81000)
WARNING: nvlog_test: Unexpected nvlog contents. Will discard contents of nvlog,
USER DATA MAY BE LOST
PANIC: This system has no disks, and thus no file system can be created on it in
process rc on release NetApp Release 7.3.2 on Thu Jan 1 00:00:56 GMT 1970
*> sysconfig -v
Thu Jan 1 00:00:55 GMT [shelf.config.unknown:info]: System storage configuratio
n is unknown
System ID:
System Serial Number:
System Rev: J0
System Storage Configuration: Unknown
System ACP Connectivity: No Connectivity
slot 0: System Board 600 MHz (TSANTSA E0)
Model Name: FAS250
Part Number: 110-00016 <-- Non-RoHS
Revision: E0
Serial Number:
Firmware release: CFE 1.2.0
Processors: 1
Processor revision: B2
Processor type: 1250
Memory Size: 510 MB
NVMEM Size: 64 MB of Main Memory Used
Firmware rev: 3.3.27
Host Loop Id: 0 FC Node Name: 5:00a:098000:0031f2
Cacheline size: 8 FC Packet size: 2048
SRAM parity: Yes External GBIC: No
Link Data Rate: 1 Gbit
slot 0: FC Host Adapter 0c (Dual-channel, QLogic 2312 rev. 2, 32-bit, L-
Host Loop Id: 0 FC Node Name: 5:00a:098100:0031f2
slot 0: Dual SB1250-Gigabit Ethernet Controller
Device Type: BCM1250
e0a MAC Address: 00:a0:98:01:e3:4f (auto-unknown-cfg_down)
e0b MAC Address: 00:a0:98:01:e3:50 (auto-unknown-cfg_down)
slot 0: ATA/IDE Adapter 0a (0x00000000000001f0)
0a.0 SanDisk SDCFB-256-911B HDX 2.15 245MB 51
2B/sect (109320B2405W2954)
Any help or suggestions greatly appreciated!
Thanks
