Legacy Product Discussions
Hi,
I know this may be a tough question to ask since the filer F740 and the os ONTAP v6.1 are quite old but we still use these in our test environment and I'm having some problems that I can't get support through netapp as we ran out of support.
My problem is that the ONTAP OS no longer boots and I was trying to upgrade to v6.3. I have downloaded the v6.3 on the floppy disks and tried to install but does not work, can anyone tell me how I would go about installing the new version?
Hi John!
Do you have the logs from the console that you're seeing when you try to boot?
Hello John,
You are in quite a predicament!
But putting the 'supportability' facts to the side, let's try to address what might be going on.
Any errors you're getting, and conditions which lead up to the errors.
What version you were running, and the version you respectively are attempting to upgrade to.
(Are you limited to 6.3? or would an attempt to 6.4.5 work - theoretically given the circumstances ofcourse)
Especially when you say, trying the install does not work - What exactly does not work.
We could be dealing with a function issue, a configuration problem, or something perhaps even addressed in the release notes of going from one version to another.
So, let us know what you can about what your current state is, and lets see if we can get you out of this situation!
Christopher
HI, thank you all foryour replys, much appreciated.
I'll try to explain what is going on here.
I have a 2 - F740 filers that was running ONTAP 6.1R1 and it keeps rebooting itself complaining of various errors. So, what I tried to do was shut one down and use the good disks on one filer. When I did that I looks like I somehow messed up the ONTAP OS?????
So, I downloaded the v6.3 on the diskettes and tried to install it and the process looked good but when the netapp goes into the maintenace mode, it defaults to v6.1. I'm thinking it's doing this because I can't get a prmopt screen to issue the "download" command????
I was able to get lots of logs yesterday. I'll try to insert some of it.
Here are some of the logs in the order they showed up:
Alpha Open Firmware by FirmWorks
Copyright 1995-2000 FirmWorks, Network Appliance. All Rights Reserved.
Firmware release 2.8_a2
Memory size is 512 MB
Testing SIO
Testing LCD
Probing devices
Testing 512MB
16MB chunks
1 to 16MB
496 to 512MB
Complete
Finding image...
Loading 3 2 disk@1
100%
Starting Press CTRL-C for special boot menu
Thu Jan 1 00:00:00 GMT [isp_timeout:warning]: 0b.10(0xfffffc00012deee0, 0x12): command timeout, quiescing bus to allow outstanding I/O to complete.
Thu Jan 1 00:00:00 GMT [isp_timeout:warning]: 0b.11(0xfffffc00012df140, 0x12): command timeout, quiescing bus to allow outstanding I/O to complete.
Thu Jan 1 00:00:00 GMT [isp_timeout:warning]: 0b.12(0xfffffc00012df3a0, 0x12): command timeout, quiescing bus to allow outstanding I/O to complete.
Thu Jan 1 00:00:00 GMT [isp_timeout:warning]: 0b.13(0xfffffc00012df600, 0x12): command timeout, quiescing bus to allow outstanding I/O to complete.
Thu Jan 1 00:00:00 GMT [isp_timeout:warning]: 0b.14(0xfffffc00012df860, 0x12): command timeout, quiescing bus to allow outstanding I/O to complete.
Thu Jan 1 00:00:00 GMT [isp_timeout:warning]: 0b.15(0xfffffc00012dfac0, 0x12): command timeout, quiescing bus to allow outstanding I/O to complete.
ispfc: Fibre Channel adapter 7 appears to be unattached/disconnected. If
adapter is in use, check cabling and seating of LRC cards in disk shelves.
Thu Jan 1 00:00:00 GMT [ispfc_init_2:error]: Initialization failed on Fibre Channel adapter 7.
NetApp Release 6.1R1: Fri Apr 20 03:08:22 PDT 2001
Copyright (c) 1992-2001 Network Appliance, Inc.
Starting boot on Fri Aug 1 20:22:12 GMT 2008
Fri Aug 1 20:22:42 GMT [net_e0:info]: Ethernet e0: Link up.
raid_checklabels(0): disk 6.2 has time/generation 1217069933/172 whereas disk 6.13 has time/generation 1217604717/176
Fri Aug 1 20:22:52 GMT [rc:EMERGENCY]: Root volume vol0, RAID group 0 is missing 3 disks and is unusable.
Fri Aug 1 20:22:52 GMT [rc:CRITICAL]: Volume vol0 is missing 3 disks from RAID group 0 and is being taken offline for this boot.
Fri Aug 1 20:22:52 GMT [rc:ALERT]: Cluster monitor: Root and Mailbox disks are uninitialized on local system.
Fri Aug 1 20:22:52 GMT [rc:ALERT]: Cluster monitor: Root and Mailbox disks are uninitialized on partner system.
Disk 6.5 is reserved for "hot spare"
1 disk is reserved for "hot spare".
Fri Aug 1 20:22:52 GMT [cf.disk.invalidMailbox:error]: Cluster monitor: partner mailbox disk data invalid
Fri Aug 1 20:22:52 GMT [raid.assim.outofdateNdisks:ALERT]: More than one disk in RAID group 0 of volume vol0 has a valid label not
consistent with all the others. These disks are assumed to be out of date;
their contents cannot be restored.
Fri Aug 1 20:22:53 GMT [rc:error]: There is an out-of-date disk 6.2 originally belonging to volume vol0, RAID group 0
Fri Aug 1 20:22:53 GMT [mgr.boot.noBloop:CRITICAL]: No disks were detected on Fibre Channel port B;
this node will be unable to takeover correctly
PANIC: No root volume found. in process rc on release NetApp Release 6.1R1 on Fri Aug 1 20:22:54 2008
version: NetApp Release 6.1R1: Fri Apr 20 03:08:22 PDT 2001
cc flags: 1
::::::::::halt after panic during system initialization
Then I tried to install the v6.3
Finding image...
Loading isa floppy
Insert Disk #2 of 6 ........ Insert Disk #6 of 6
100%
Starting Press CTRL-C for floppy boot menu
Fri Aug 1 20:35:11 GMT [ispfc_init_2:error]: Initialization failed on Fibre Channel adapter 7.
NetApp Release 6.3: Wed Aug 7 23:04:57 PDT 2002
Copyright (c) 1992-2002 Network Appliance, Inc.
Starting boot on Fri Aug 1 20:34:42 GMT 2008
Fri Aug 1 20:35:16 GMT [net_e0:info]: Ethernet e0: Link up.
Swarm Replay Stats Daemon Started
Fri Aug 1 20:35:16 GMT [config.noBloop:CRITICAL]: No disks were detected on Fibre Channel port B; this node will be unable to takeover correctly
This boot is of OS version: NetApp Release 6.3.
The last time this filer booted, it used OS version: NetApp Release 6.1R1.
This boot is of an OS which has RAID version 5 and WAFL version 28;
The last time this filer booted, it used an OS version that contained
RAID version 4 and WAFL version 13.
If you do not want your file system upgraded, choose
Maintenance mode or reboot with the correct
OS version. If you upgrade, and then want to return to the
previous OS, you will need to revert your filesystem.
(1) Normal boot.
(2) Boot without /etc/rc.
(3) Change password.
(4) Initialize all disks.
(5) Maintenance mode boot.
Selection (1-5)? Fri Aug 1 20:35:30 GMT [ses_admin:error]:
XL500 shelf 1 on channel 6 reports a critical condition
Power Supply
Element 2: critical status
power supply failed
Fri Aug 1 20:35:31 GMT [ses_admin:error]:
XL500 shelf 0 on channel 6 reports a critical condition
Power Supply
power supply failed
100%
(1) Normal boot.
Power Supply
power supply failed
Power Supply
power supply failed
There are more errors but maybe we can start from here??? I've also attached all the captured data from the console.
Thanks guys......
Wow John,
It looks like your system is going through a number of challenges.
Some of those look like hardware failures actively, or concurrently?
If I'm reading this correctly (and you'd be the best to know) you had loops go offline, power supplies showing as failed in shelves, and more?
Is this correct?
I know you're in a situation rightnow, with the inability to load up a new version and it being unbootable as it looks.
What other circumstances led up to this? did you have any failures, or faliure of hardware over time?
Can you detail the number of items which might be currently failed, and/or can you verify the validity of your cables used for loops, shelves and Power, etc?
Let me know if these are truly failed items and we can see how we can work through this if possible - this is of a particular concern itself!
*** Booting in maintenance mode because of loop inconsistency ...
ispfc: 10 loop-initialization events seen in 60 seconds on Fibre Channel adapter 7: indicates loop stability problem.
Thanks John, and look forward to some details - Hope we can help with this!
Christopher
John -
Let's start with the basics. Please power down the system and reseat the VEM modules in the back of your FC shelves on both the 6 and 7 loops. Additionally, please reseat the cables there as well. Finally, please pull and reseat disk 6.4. We need to NOT floppy boot to 6.3 right now as your filesystem is 6.1. Floppy booting to 6.3 will upgrade raid but not WAFL, and leave us in a much more difficult position.
After you have reseated, please boot into maintenance mode and issue 'vol status -r'. My concern is this line in your console logs:
This means that disk 6.2 is out of date in the raid group.
Additionally, it looks like disk 6.4 is being chatty -
6.3 0 -156 16 0 18446744073709501589 18446744073709501589
6.4 0 0 6 0 18446744073709551551 18446744073709551551
6.5 0 0 3000 108 2 2
We have underruns on 6.3 and CRC errors on 6.5 This is a classic example of a disk being the cause of loop instability.
Hi,
This may sound stupid but what is a VEM module?
And thanks so much to all of you who responded.
The VEM module is the module in the back of the shelf that the FCAL cable plugs into. In newer shelves it's a LRC or an ESH, but in your rev, it's called a VEM.
So that would be the fiber cable ports on the back of the filer ?
On the other end
The cables come out of the filer and plug into the shelf. Where they plug into the shelf - that's the VEM module.
Thanks,
I'll try your suggestion later, when I can take my laptop and capture some output to post.
Ok,
So, I took out all the VEM's then put them back in and started the filer and see the following output being repeated:
Testing SIO
Testing LCD
Probing devices
Testing 512MB
16MB chunks
1 to 16MB
16 to 32MB
32 to 48MB
48 to 64MB
64 to 80MB
80 to 96MB
96 to 112MB
112 to 128MB
128 to 144MB
144 to 160MB
160 to 176MB
176 to 192MB
192 to 208MB
208 to 224MB
224 to 240MB
240 to 256MB
256 to 272MB
272 to 288MB
288 to 304MB
304 to 320MB
320 to 336MB
336 to 352MB
352 to 368MB
368 to 384MB
384 to 400MB
400 to 416MB
416 to 432MB
432 to 448MB
448 to 464MB
464 to 480MB
480 to 496MB
496 to 512MB
Complete
Finding image...
Loading 3 3 disk@0
Can't open boot device
Startup failed
Testing SIO
Testing LCD
Probing devices
Testing 512MB
16MB chunks
1 to 16MB
16 to 32MB
32 to 48MB
48 to 64MB
64 to 80MB
80 to 96MB
96 to 112MB
112 to 128MB
128 to 144MB
144 to 160MB
160 to 176MB
176 to 192MB
192 to 208MB
208 to 224MB
224 to 240MB
240 to 256MB
256 to 272MB
272 to 288MB
288 to 304MB
304 to 320MB
320 to 336MB
336 to 352MB
352 to 368MB
368 to 384MB
384 to 400MB
400 to 416MB
416 to 432MB
432 to 448MB
448 to 464MB
464 to 480MB
480 to 496MB
496 to 512MB
Complete
Finding image...
Loading 3 3 disk@1
Startup failed
I don't see all the other errors that I was seeing before.
Alrighty. That's looking good. Well, better at least 🙂
Do you have the 6.1 boot floppies kicking about? What I'd like to do is boot off of those, go into maintenance mode (option 5 on the 1-5 menu), and issue a 'vol status -r' and see what shape the volumes are in.
I don't have the 6.1 floppies,think I can download these. After the downloads, I'll see if I can get to the maintenance mode and issue the command you suggested.
Tks.
Ok, I was able to make the install floppies for the v6.1R1 and after the 4th floppy got loaded it complained of the following:
100%
Starting boot on Mon Aug 18 20:24:54 GMT 2008
Mon Aug 18 20:25:09 GMT [net_e0:info]: Ethernet e0: Link up.
Mon Aug 18 20:25:36 GMT [scsi.cmd.pastTimeToLive:error]: Device 7.4: request failed after retry #0: cdb 0x1b.
ispfc: 15 loop-initialization events seen in 60 seconds on Fibre Channel adapter 7: indicates loop stability problem.
Mon Aug 18 20:26:29 GMT [ses_admin:error]: Disk 7.4 not detected by Enclosure Services.
ispfc: 14 loop-initialization events seen in 60 seconds on Fibre Channel adapter 7: indicates loop stability problem.
Mon Aug 18 20:27:10 GMT [ispfc_init_2:warning]: Resetting Fibre Channel adapter 7.
Mon Aug 18 20:27:22 GMT [scsi.cmd.pastTimeToLive:error]: Device 7.4: request failed after retry #0: cdb 0x1b.
Mon Aug 18 20:27:59 GMT [ses_admin:error]: Disk 7.4 not detected by Enclosure Services.
Mon Aug 18 20:27:59 GMT [ses_admin:error]: Possible actual addresses:
7.9 (shelf 1 bay 1)
Drive loop addresses failed consistency check.
Additional information is being syslogged.
ok
okay, looks like we still have loop instability. do you have a sysconfig -r from a previous autosupport by chance? or for that matter do you know which disks made up the root volume?
we have something causing trouble on those loops. what i'd like to do is to tear out whatever is not absolutely necessary to boot this system. i.e. if the root volume is kept on disks 7.1, 7.2, and 7.3, pull off all shelves and loops with the exception of the first shelf on the 7 loop.
make sense?
