Legacy Product Discussions
vFiler migrate errors on CIFS not licenced for destination
fletch2007
We don't use CIFS, but by default the vFilers we created have the CIFS protocol checked (along with iscsi and rsh) when all we want is NFS.
Q: How do I disable the CIFS, iscsi, rsh protocols FROM THE COMMAND LINE to allow the vFiler migrate to proceed?
I did it through the FilerView MultiStore->Manage wizard on a test vFiler, but the wizard touches exports and I can not risk that in production.
From the audit logs, it looks like the wizard is updating a registry setting? - how can I do this from the command line?
Fri Oct 15 15:51:50 PDT [netapp-02: registry_control:debug]: root: MODIFY:options.vfconfig.vm64-vf-01.cifs_disabled:1
thanks
1 ACCEPTED SOLUTION
rshiva
Hi there,
Have you tried the "vfiler disallow" command on ONTAP? The vfiler allow will list the enabled protocols of the vfilers on a storage system.
Thanks and regards
Shiva Raja
3 REPLIES 3
ekashpureff
Cifs:
Edit 'cifs start' out of /etc/rc
cifs terminate
options rsh.enable off
options iscsi.enable off
Cifs and iscsi:
license delete cifs/iscsi
At your service,
Eugene Kashpureff
rshiva
Hi there,
Thanks and regards
Shiva Raja
fletch2007
vfiler disallow did the trick!
thanks
PS: the other method had been suggested outside the vfiler context
