Microsoft Virtualization Discussions
Difference between individual commands and putting them together in a script
mrinal
Hi all,
When I run the below set of command from the CLI they work as expected. But when I run them in the script I do not get any information. Looking for comments on possible causes....
==On CLI==
PS C:\Users\mrinal\Documents\powershell> $vserver_listing = Get-NcVserver -Template
PS C:\Users\mrinal\Documents\powershell> $vserver_listing.VserverType = "data"
PS C:\Users\mrinal\Documents\powershell> $vserver_list = Get-NcVserver -Query $vserver_listing
Vserver                   State      VserverType   Comment
madden-vs1                running    data
madden-vs2                running    data
mrinal-vs02               running    data
rfl_test                  running    data
upper                     running    data
UPPER                     running    data
vs01                      running    data
vs1                       running    data
vs-esrf                   running    data
==Via ps1 script==
PS C:\Users\mrinal\Documents\powershell> .\vserver_dr_collect.ps1
Cluster Name / IP : 10.10.10.10
Cluster Admin UserName : admin
Cluster Admin Password : *********
Name                                    Credential                              HostUser
10.10.10.10                            System.Management.Automation.PSCrede... DOMAIN\dummy
Select Vserver : vs01 <<<<<<< The lines above this are blank on the console as well.
2 REPLIES 2
timothyn
Can you attach the script (or a subset that reproduces the problem)?
Thanks!
mrinal
Script attached. I worked around the problem by printing each unit of the array with a foreach loop. Appreciate pointers to improve this logic. Or any other part of the script for that matter.
