Microsoft Virtualization Discussions
Invoke-ncssh parsing problem?
koenraad0
Example to reproduce:
Invoke-NcSsh -Command 'system node run -node node1 -command "priv set diag;ls /etc/log;priv set admin"'
(Replace node1 with the name of a node)
Response:
Value        : Warning: These diagnostic commands are for use by NetApp
                        personnel only.
               Error: "ls" is not a recognized command
                 "priv set" is not supported: use the "set -privilege" command.
priv set diag --> runs on the node
ls /etc/log & priv set admin --> do not run on the node.
This does work when run in a putty window.
I think it fails when you use ; to bundle commands to send to the node.
Another example:
Invoke-NcSsh -Command 'system node run -node ncb1-01 -command "hostname;hostname"'
Netapp PowerShell Toolkit 4.60
NetApp Release 9.3P5
2 REPLIES 2
markweber
try:
Invoke-NcSsh -Command 'set d;system node run -node node1 -command "ls /etc/log"'
(invoke-ncssh doesn't work for me right now, so i'm not able to test it)
koenraad0
Thanks, this solved the problem.
