Microsoft Virtualization Discussions
Need help with Powershell commands for CIFS Sessions
MAHESH1111111
I was trying to script to list all the open CIFS connections along with the Complete File path that is open to identify the share the user is connected to, then I could filter the share I’m interested in and disconnect all the sessions related to that share.
I couldn’t find a Get command that can give this information, For Ex:
  • Get-NcCifsSessionFile – gives the file name but not the entire path.
  • Get-NcCifsSession – gives the ConnectionId but not the path.
I remember you mentioned about doing this completely using Powershell, would you be able to help identify the commands for below:
  • Get the list of Files (along with their Share Paths) that have an ongoing session along with Connection ID.
  • Use the Connection ID to kill the session of the user.
Thanks for your help in advance.
2 REPLIES 2
asulliva
Hello @MAHESH1111111,
The share name is a property of the object returned by Get-NcCifsSessionFile.  You can see the full path using this snippet:
Get-NcCifsSessionFile | Select SessionId,Vserver,Share,Path
If you want a bit more thorough output, you could do something like this:
Get-NcCifsSessionFile | %{
    $session = Get-NcCifsSession -SessionId $_.SessionId
    $data = "" | Select "WindowsUser", "SVM", "Path"
    $data.WindowsUser = $session.WindowsUser
    $data.SVM = $_.Vserver
    $data.Path = "\\$($session.LifAddress)\$($_.Share)\$($_.Path)"
    $data
Hope that helps.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
MAHESH1111111
Thanks so much Andrew - updated your command to come up with below:
Get-NcCifsSessionFile | Select SessionId,Vserver,Share,Path,ConnectionId,HostingVolume,Node | Select-String -Pattern <ShareName> | Get-Unique
Close-NcCifsSession -ConnectionId <ConnectionId> -Node <Node> -VserverContext <DataVserver> -Confirm:$false -SessionId <SessionId>
Above two commands will give the list of open files and sessions for a particular share and the details we get from that command can then be scripted to dosconnect the same session.
