Microsoft Virtualization Discussions
SSL issues using -controller argument with ONTAP PowerShell
dearmon
So, I'm having an issue that I'm hoping is a simple fix, but am not having any luck getting it resolved.  When using the DataONTAP PowerShell to do simple stuff like get-naVol, I have to do a connect-nacontroller first every time, instead of just being able to specify -controller in the arguments for the command.  If I do use -controller, I get something like this:
PS X:\powershell> get-nasnapmirror -Controller xxxfiler
Get-NaSnapmirror : Could not connect to xxxfiler on port 443 for protocol HTTPS.
At line:1 char:17
+ get-nasnapmirror <<<<  -Controller xxxfiler
    + CategoryInfo          : InvalidOperation: (NetApp.Ontapi.Filer.NaController:NaController) [Get-NaSnapmirror], NaConnectionSSLException
    + FullyQualifiedErrorId : ApiException,DataONTAP.PowerShell.SDK.Cmdlets.Snapmirror.GetNaSnapmirror
SSL is *NOT* enabled on the filers here.  Enabling it isn't an option at present.  How can I force PowerShell to use RPC to make these requests?  if I connect to the filer first, it works fine (like this) and uses RPC:
PS X:\powershell> connect-nacontroller xxxfiler
OntapiMajorVersion : 1
OntapiMinorVersion : 7
Protocol           : RPC
Vfiler             :
Address            : xxx.xxx.xxx.xxx
Port               : 0
Credentials        :
ValidateIncoming   : False
ValidateOutgoing   : False
Trace              : False
BaseSnapshot         : xxx-filer(0000000000)_xxxfiler_maillogs1.1820
Contents             : -
CurrentTransferError :
CurrentTransferType  :
DestinationLocation  : xxx-filer:xxxfiler_maillogs1
LagTime              : 10741
LastTransferDuration : 1682
LastTransferFrom     : -
LastTransferSize     : 769868
LastTransferType     : -
MirrorTimestamp      : 1286406160
SourceLocation       : xxxfiler:maillogs1
State                : source
Status               : idle
TransferProgress     : 0
-----------output cut off --------------
1 REPLY 1
cknight
Hello, dearmon.
The value passed to a Toolkit cmdlet's -Controller parameter is of type NaController (the type returned by Connect-NaController), not System.String.  So here are the typical usage examples for RPC connections:
1. Pre-connect
Connect-NaController xxxfiler
Get-NaSnapmirror
2. Save the value
$xxxfiler = Connect-NaController xxxfiler
Get-NaSnapmirror -Controller $xxxfiler
3. All together
Get-NaSnapmirror -Controller (Connect-NaController xxxfiler)
All of these work with HTTP/HTTPS connections as well, given the needed -Credentials parameter to Connect-NaController.
