Network and Storage Protocols
Connectivity for FAS2240-2
support_3
Hi,
Anyone help on the cable connectivity for FAS 2240-2 Dual controller For FC san
ACP port is there is that required for connectivity if yes how?
2 REPLIES 2
saranraj456
ACP is not for connectivity,meant for automatic disk shelf management.
For reference on connectivity https://communities.netapp.com/thread/21508
Saran
VernMurray
The FC ports, if they are installed, are configured as initiators by default. You will need to reconfigure them to target mode.
Use these commands:
filer1> fcadmin config -d 1a
filer1> fcadmin config -d 1b
filer1> fcadmin config -t target 1a
filer1> fcadmin config -t target 1b
filer1> fcadmin config -e 1a
filer1> fcadmin config -e 1b
filer2> fcadmin config -d 1a
filer2> fcadmin config -d 1b
filer2> fcadmin config -t target 1a
filer2> fcadmin config -t target 1b
filer2> fcadmin config -e 1a
filer2> fcadmin config -e 1b
