Network and Storage Protocols
Is NDMP on Ontap-V/Data ONTAP Edge possible?
IVC
Hello,
My current situation is as follows: We used to be heavy on various NetApp arrays, and our legacy backup system was BackupExec12. Some tape backups from net apps were done using NDMP backups. Since we migrated loads to HCI and Cloud and decommissioned all Netapp hardware.
If I need to restore an old NDMP backup from tapes, would using Ontap-V/Edge as a destination be possible?
I've checked the docs, but I can't see Ontap-V/Edge documentation mention NDMP at all - neither as a supported nor unsupported feature.
What are possible alternatives?
1 ACCEPTED SOLUTION
chamfer
Hi @IVC
NDMP is supported in ONTAP Select.
"Yes, ONTAP Select supports all non-hardware bound features of ONTAP 9.x"
https://kb.netapp.com/onprem/ontap/ONTAP_Select/Does_ONTAP_Select_support_NDMP
1 REPLY 1
chamfer
Hi @IVC
