Network and Storage Protocols
Performance problem with VMWare View Persona Management and Profile redirected on a NetApp CIFS Share
f_duranti
Hi all, we are having a performance problem with VMWare View client that use Persona Management for User Profile.
We have an infrastructure with persistant desktop (linked clone) and we use Persona Management to cache user data from the Persona Profile share on the windows desktop.
Our Infrastructure is composed by a 3270HA (so 2 head) with 24 SAS 15k 450 GB each. We've a single aggregate per head. On one head we have VM disks, on the second head there is the Persona Management cifs share.
NetApp release is 7.3.6P2. Persona management share is on a vfiler (for Disaster Recovery Management).
ESX host have 2x10Gbit network dedicated to NFS Storage/Vmotion network and 2x10 Gbit for Virtual Machine networks.
3270 has 2x10Gbit (HA) on the NFS Storage Network and 2x 10Gbit (HA) on the same VLAN with Virtual Machines.
Virtual Desktop are windows 7 machine and SMBv2 is used on vfiler and VM.
When users log in Persona Management check difference between local cached data and those present on the CIFS Share. This operation with 30000 (so not really much) will take about 6 minutes.
We used the same set of file and shared them on a Windows 2008 server (in this case the traffic is also passing through a firewall) and it takes about 8-10 seconds for the user to login.
Anyone had those kind of problem or have any idea and know if there's any kind of options we can setup (like SMB V2 not working good, disable oplocks, tcp options) ?
Those are the options cifs on the vfiler:
cifs.LMCompatibilityLevel 1
cifs.audit.account_mgmt_events.enable off
cifs.audit.autosave.file.extension
cifs.audit.autosave.file.limit 0
cifs.audit.autosave.onsize.enable off
cifs.audit.autosave.onsize.threshold 75%
cifs.audit.autosave.ontime.enable off
cifs.audit.autosave.ontime.interval 1d
cifs.audit.enable off
cifs.audit.file_access_events.enable on
cifs.audit.liveview.allowed_users
cifs.audit.liveview.enable off
cifs.audit.logon_events.enable on
cifs.audit.logsize 524288
cifs.audit.nfs.enable off
cifs.audit.nfs.filter.filename
cifs.audit.saveas /etc/log/adtlog.evt
cifs.bypass_traverse_checking on
cifs.comment
cifs.gpo.enable off
cifs.gpo.trace.enable off
cifs.grant_implicit_exe_perms off
cifs.guest_account
cifs.home_dir_namestyle
cifs.idle_timeout 1800
cifs.ipv6.enable off
cifs.max_mpx 1124
cifs.ms_snapshot_mode xp
cifs.netbios_aliases
cifs.netbios_over_tcp.enable on
cifs.nfs_root_ignore_acl off
cifs.oplocks.enable on
cifs.oplocks.opendelta 0
cifs.per_client_stats.enable off
cifs.perfmon.allowed_users
cifs.perm_check_ro_del_ok off
cifs.perm_check_use_gid on
cifs.preserve_unix_security off
cifs.restrict_anonymous 0
cifs.restrict_anonymous.enable off
cifs.rpcfd_timeout -1
cifs.save_case on
cifs.scopeid
cifs.search_domains
cifs.show_snapshot off
cifs.shutdown_msg_level 2
cifs.sidcache.enable on
cifs.sidcache.lifetime 1440
cifs.signing.enable off
cifs.smb2.client.enable on
cifs.smb2.durable_handle.enable on
cifs.smb2.durable_handle.timeout 16m
cifs.smb2.enable on
cifs.smb2.signing.required off
cifs.snapshot_file_folding.enable off
cifs.symlinks.cycleguard on
cifs.symlinks.enable on
cifs.trace_dc_connection off
cifs.trace_login off
cifs.universal_nested_groups.enable on
cifs.weekly_W2K_password_change off
cifs.widelink.ttl 10m
2 REPLIES 2
ambankiowa
Did you ever figure anything out for this?  We are having the same problems with a somewhat similar setup.
f_duranti
I think the problem is now solved but now I don't remember what the exact solution was and I should ask to people responsible for View that now are in holidays.
If I remember well there is some kind of bug in Persona Management agent and is now solved with the 5.1 upgrade (but I'm not sure).
