Network and Storage Protocols
Thin provision
saranraj456
Hello ,
I am going to Create a thin provisioned LUN.These are the steps i did
1.Create a volume
2.Select a space guarantee none for the volume.
3.create a LUN
4.enable the space reserve in LUN
And my query is,did the points 2 & 4 are both combinely needed to form an thin provisioned LUN?
(or)
Should i use either one of these two options?
Kindly clarify.
Cheers,
Saran
3 REPLIES 3
bhanojiisit
Dear Saran,
When you select the "space guarantee none for the volume". This means that the volume is thin provisioned. For the LUN also to be this provisioned you need to set the space reservation disabled.
If you need only the LUN to be this provisioned then you need to set the "space guarantee volume for the volume". And the LUN space reservation to be disabled.
Below are the comamnds for enabling the thin provisioning on the volume and lun.
Volume: vol options “targetvol” guarantee none
LUN: lun set reservation “/vol/targetvol/targetlun” disable.
Hope this helps.
Regards,
Bhanoji
saranraj456
Hi Bhanoji,
Thank you very much for your answer !!!
Does the reserve case will work, setting the space guarantee as none for volume and reserving the space for LUN?
Thanks,
Saran
chinchilla
A space-reserved LUN on a volume with guarantee set to none will not reserve its capacity. lun show -v will provide following output:
lun show -v /vol/test/test
        /vol/test/test              50.0g (53694627840)   (r/w, online)
                Serial#: Hn/5m4gyMgHE
                Share: none
               Space Reservation: enabled (not honored by containing Aggregate)
                Multiprotocol Type: windows
You can see TR 3483 for more details.
