ONTAP Discussions
ADP
corrine
hello everyone   I want to know how to determine the size of each partition of a disk, is there any logic? Because it seems that the data partitions are different for different types of drives.
I  just  try calculating  usable space instead of fushion,so I want to kow the principles of calculation
Thank you very mucn
1 ACCEPTED SOLUTION
SpindleNinja
It's laid out in hwu.netapp.com. under -> platforms -> <select system(s) ->  ADP Root Partition Configuration. and can vary.
1 REPLY 1
SpindleNinja
