ONTAP Discussions
Copy using ndmpcopy for qtree into same Storage
MRF-Corp
copy to same storage - cluster mode
I need to merge the two qtree files
We have  a qtree source /vol/vol_webfiles/SAT_Gravador2 and need the copy to /vol/vwebfiles/recordings_sate
My doubt is in relation to the command line to do this procedure for being qtree
Thank you for your help!
2 REPLIES 2
MRF-Corp
Hello Team
I don't know the ndmpcopy utility well and I would like to know if the command below works well.
Xunap002::> node run local ndmpcopy -i /vol/vol_webfiles/SAT_Gravador2 /vol/vol_webfiles/recordings_sate
Thanks
Mjizzini
ndmpcopy [options][source_filer:]source_path [destination_filer:]destination_path
In theory The qtree path will be the volume_path/qtree_name "/vol/volume_name/qtree_name
How to run ndmpcopy in Clustered Data ONTAP
