ONTAP Discussions
DM5000H Storage with Ontap 9.7 with information alert led amber
ahmar
Hi Team,
We have new storage configured and all looks good but we have an information alert led  amber.
This appeared once we had down a power cyle of the system and reseated one of the power supply and the controller.
No fault as per logs and ,Kindly advice
regards
ahmar
1 ACCEPTED SOLUTION
ahmar
Hi Team,
Finally issue solved after Power cycle of the Storage System. No further amber Led.
All appears green.
Thanks all for the advice and input
11 REPLIES 11
Ontapforrum
Most likely - "Uncleared alarm set on the shelf" .
Looks like it is a Lenovo Hardware running ONTAP software.  Interesting, I am sure there is a Lenovo Support for this hardware ? Have you tried reaching out to them first. In case they direct you to NetApp, then please raise a ticket with NetApp support.
ahmar
Hi, Lenovo support seems to be clue less after exchange of emails, that's why I came to Netapp forum.
Comment from lenovo support  >>With all this being said, I would like to know if it would be possible
to run the following set of commands that may give us a better hint on
what exactly is causing the amber LED to show up:
::>set -priv advanced
::*>system controller fru led show       >> didnt work
Command not supported on this platform.
Use this command instead: system controller service-event show
::*>system controller service-event show
This table is currently empty
Now is there a way to clear "Uncleared alarm set on the shelf"   as you mentioned?
Additionally i found the attached article. If you can check this.
Highly appreciate your input.
Thanks
Thanks
Ontapforrum
Let me take a look.
In the mean time, could you quickly give the output of this command:
Get to the Node-shell:
::> node run -node <node>
Node> storage show fault -v
Look under the Power Supplies: Element Status section.
Following is the output from one of our filer Node:
Power Supplies:
Element Status Status Bytes Status Descriptions
1: OK 01,00,00,A0 RQSTED ON
2: OK 01,00,00,A0 RQSTED ON
ahmar
This is already executed and and attached is the output, nothing found.
Power Supplies:
Ontapforrum
That article you shared does not apply as you are on 9.7 (latest) software. Overall, your system seems alright.
It has to be something to do with uncleared alert, I suggest raise a ticket with NetApp support.  There is a article in NetApp KB, which suggests contacting support.
Attention amber LED ON in a shelf without any alert reported
https://mysupport.netapp.com/site/article?lang=en&type=solution&page=%2FAdvice_and_Troubleshooting%2FData_Storage_Systems%2FFAS_Systems%2FAttention_am...
ahmar
Thanks for your input, Pls guide how to raise a ticket in Netapp as we have Lenovo box running Ontap.
Are we eligible for the Ontap direct support?
Ontapforrum
Please reach out to the nearest contact centre (wherever you are, numbers are in the link below)
NetApp Global Services Contacts:
https://www.netapp.com/us/contact-us/support.aspx
As I read on the internet, NetApp & Lenovo has formed partnership, so they must have given some thought to 'support' for Hardware/Software. Just give a call to NetApp support, they will guide you further.
Also, do you have an Account Manager for the Lenovo Hardware(ONTAP) for your company, may be he will be able to guide you on 'How you can reach out to NetApp/Lenovo for Hardware/Software related issues'.
Let me also reach out @Drew_C : He may be able to  guide you on this.
ahmar
Hi,
Below was the response from Lenovo Tech support after i contacted them for email notification issue and I was directed to them by Lenovo Professional services guy only after he failed to come up with the correct commands. Which you have finally shared. Hopefully they will work.
"Kindly be informed that we are hardware break and fix only team, for any other issues including configuration, how to .. etc. please contact Lenovo professional services".
ahmar
And further they are sending Customer satisfaction form for the support, sounds like a cruel joke.
Ontapforrum
Certainly very disappointing experience. I am not surprised that Lenovo Support is clueless about ONTAP, but I am surprised about the fact that the Lenovo Hardware is running ONTAP Operating system and it is the most important piece, and should have skilled support. I would think such calls  should be directed to NetApp support.
Have you tried reaching out to NetApp support yet ? Why don't you reach out to top management of Lenovo about this experience.
Just give a call to NetApp support number I provided and let us know the response, so that we can work out what is the best way to get some help here.
ahmar
Hi Team,
All appears green.
