ONTAP Discussions
Diff between "IOM3 Firmware" and "ACP_IOM Firmware"?
WSANDERSATFLEXERA
We are trying to get our ducks in line before an upgrade. I see two different versions of IOM3 firmware at https://support.netapp.com/NOW/download/tools/diskshelf/: "IOM3 Firmware rev 0172" and "ACP_IOM3 Firmware rev 0141", both for part number SP-5712A-R6.  I see no part number for the IOM3 in the output of sysconfig -a/-v. Does anyone know how to tell the difference?
Although, when I download the zip file with the shelf FW, I do get both shelf and ACP firmware. So I assume both "IOM3 Firmware rev 0172" and "ACP_IOM3 Firmware rev 0141" are part of the package?
Does the IOM3 upgrade clobber one of dual SAS paths if it's autoinstalled as part of the background upgrade? (I understand it
s supposed to be nondisruptive.) If so, is it even necessary to update the IOM3 before a OnTAP upgrade? As I understand it the upgrade (8.0.2 to 8.1.4 in our case) will do it anyway.
Thanks w
1 ACCEPTED SOLUTION
JGPSHNTAP
Wiley,
If you are unsare about redundant paths, run storage show disk -p to ensure you are MPHA, also, run config advisor against your cluster to see
All IOM firmware should be NDU.  I've done hundreds of shelf module upgrades and never have run into an issue.
What version on ontap are you running and version of IOM are you running?
3 REPLIES 3
WSANDERSATFLEXERA
Update: Downloading the zip file, I do get both shelf and ACP firmware. I have successfully updated the ACP but I am holding off on IOM3 since I am not 100% sure it will be non disruptive - I have no reason to suspect that I do not have redundant SAS paths, but I am not 100% sure since the filer is in a remote location and I can't inspect the cabling. I will put it off until a time close to the actual OnTAP upgrade, or just let the OnTAP upgrade do it..
JGPSHNTAP
Wiley,
WSANDERSATFLEXERA
OK, shelf upgrade worked fine, no disruption. Thanks for the help. It did take 2 passes, a couple shelves failed to download on the first pass but succeeded on the second pass.
