ONTAP Discussions
Flash Pool - AWA detailed output - Low cacheable reads with high read hit rate
pedro_rocha
Hi,
I am trying to analyze Flash Pool candidacy and optimal cache size for an ONTAP cluster. It is running ONTAP 9.3P13. I followed the instructions on this link.
So far so good, been able to interpret most of its output. But then I tried to see the detailed output using the -t option in the print command. It shows information about the volumes in the aggregate that are the best candidates for being on a Flash Pool aggregate.
Happens that for a specific aggregate, the #1 volume in the list is the following:
Volume #1 VOL_XYZ
Summary of the past 7 intervals
                                                     max
Read Throughput (MB/s): 21.545
Write Throughput (MB/s): 12.757
Cacheable Read (%): 0
Cacheable Write (%): 12
Max Projected Cache Size (GiB): 1.856
Projected Read Hit (%): 50
Projected Write Hit (%): 8
So, could someone explain why and how could this volume have 0% of cacheable reads and even so present a Projected Read Hit of 50%?
Regards,
Pedro Rocha.
2 REPLIES 2
paul_stejskal
Because it is inserted with the writes. If you need specific help,  your SE on your account team can help you review the AWA output as well.
pedro_rocha
Hello Paul,
I just wanted to understand that output. There are other volumes with apparently strange values. Take a look:
Volume #3 vol_ZXC
max
Read Throughput (MB/s): 17.398
Write Throughput (MB/s): 3.266
Cacheable Write (%): 0
Max Projected Cache Size (GiB): 0.036
Projected Read Hit (%): 12
Projected Write Hit (%): 0
"No cacheable data" but 12% read hit, top 3. How come?
Besides that it would be nice to understand what are the metrics that made up this top 8 rank. Looking at them does not seem to translate the aggregate recommendation.
Pedro
