ONTAP Discussions
Gateway not configured for management interface of Storage Virtual Machine?
netappmagic
I am receiving a warning message in "Active IQ", shown as attached, and only on one of 4 nodes in the cluster
What should be the right management LIF and it's GW for SVM's and look missed here?
I already have a "admin" LIF created for each SVM, and with the role type of "data". Dont know what other role types should I have here? Also, there is already a gateway configured for this LIF as shown in "route show..".
6 REPLIES 6
TMACMD
Show us the output of route show. Maybe something is wrong. You could always mask out the first two octets
netappmagic
::> route show
Vserver             Destination     Gateway         Metric
a
                    0.0.0.0/0       x.x.82.1     10
                    0.0.0.0/0       x.x.92.1     40
b
                    0.0.0.0/0       x.x.82.1     20
                    0.0.0.0/0       x.x.90.1     30
                    0.0.0.0/0       x.x.92.1     10
c
d
d
f
g
h
                    0.0.0.0/0       x.x.82.1     30
                    0.0.0.0/0       x.x.90.1     20
                    0.0.0.0/0       x.x.91.1     10
i
                    0.0.0.0/0       x.x.76.1     30
                    0.0.0.0/0       x.x.90.1     10
Again, it is complaining about only one node among 4 nodes.  My understanding, there is no so called management LIF for a SVM, only node has management role.
TMACMD
Ok....back at a PC now and I can read your image.
That is actaully complaining about (looks like 😎 SVMs not having a default gateway.
It is a best practice for each SVM to have at a minimum of a mgmt LIF for connections.
This LIF would have a default gateway defined. This way, you NFS/CIFS/iSCSI data can stay unrouted and work just fine.
This LIF does not need any data protocols (-data-protocol none) and has a firewall policy of mgmt.
heightsnj
netappmagic
I guess my question should be:
What such LIF should look like or how should such LIF be created?
Because I already have a LIF with mgmt firewall policy for each SVM, and with such gateway:
0.0.0.0/0 10.192.82.1, as shown in my previous output. Was this gateway defined incorrectly?
netappmagic
Can some experts please pin-point the issue here? it looks I already have the default gateway for the mgmt LIF's of all SVM's. Please check "route show" outputs (.18.x is the mgmt network).
