ONTAP Discussions
Get-NcVolSize command not reporting volsize correctly when > 1024GB using Ontap Powershell Toolkit
lafoucrier
Hello Powershell Coders,
My config :
Powershelltoolkit : 9.6.0 ou 4.5.0
Dataontap : 9.4P2
I'm facing a strange problem with command   Get-NcVolSize :
- volsize  < to 1024 GB or a strict multiple of 1024GB  (ex : 2048GB) is reported correctly,
- volsize  > to 1024 GB or not strict multiple of 1024GB  (ex : 1025GB) is reported incorrectly (equal to 0 systematically).
This behaviour have a side effect on "Set-NcVolSize" command, for volume > to 1024GB or not strict multiple of 1024, and make the resize command fail!
Someone experiencing the same issue/ has a workaround for this?
Many thanks in advance.
Best regards,
Yannick
13 REPLIES 13
donny_lang
Can you show us the command you're running and the output where the volume size is reported incorrectly (sanitizing volume/vserver names as necessary)?
Thanks!
Donny
lafoucrier
here is the command i use (very simple) :
Get-NcVolSize  <volume name> -VserverContext <vservername>
when the volume is under or equal to 1024 (return in json format) :
"VolumeSize": 548682072064,
"IsReadOnlyFlexVol": false,
"IsReplicaFlexVol": false,
"IsFixedSizeFlexVol": false
when the volume is above 1024 (here set to 1025) (return in json format) :
"VolumeSize": 0,
lafoucrier
Hello Donny,
Is the last informations I give sufficient?
Did you have reproduce my issue?
thanks in advance,
donny_lang
I am not able to replicate this issue, unfortunately. However, I do not have a system running 9.4 available to determine if it is something specific with that version - I have 9.3 in production and 9.6 in the lab; neither of them exhibit the same issue with version 9.6 of the PS Toolkit.
lafoucrier
thank you for the tests.
During september I will update my FAS in 9.5 or 9.6, I'll retry test after that and update the thread.
lafoucrier
Hello,
I've updated my FAS Arrays during september as I said i my earlier post, but I observe the same issue....
FAS2620 in 9.5P7
powershell module : 9.6.0
powershell server : Windows 2012R2 (6.3.9600)
RajeshPanda
@donny_lang  Can you please help @lafoucrier
Thanks
Rajesh
lafoucrier
Hi Donny,
I've updated my FAS Arrays during september as I said i my earlier post, but I observe the same issue, is there any other test I can do to debug the situation (or maybe au workaround with another cmdlet)?
thanks in advance,
FAS2620 in 9.5P7
powershell server : Windows 2012R2 (6.3.9600) or Windows 2016
regards
donny_lang
Sorry for the delay. On the larger than 1024GB volume, can you try to collect the volume size from Get-NcVol instead to see if that works:
Get-NcVol -Vserver <vserver> -Volume <volume> | fl TotalSize
It'll (theoretically) report the volume size in bytes, which should be a non-zero number. If that doesn't work, we can try to query it via the ZAPI call directly with Invoke-NcSystemApi and see if that yields any different output.
lafoucrier
Hi Donny,
Thank you, this command works well.
What i'm trying to do initialy was a
Set-NcVolSize -NewSize <newSize> -Name <volname> -VserverContext <vservename>
but this command fail with the same behaviour as Get-NcVolSize
Do you also have a command to bypass this one?
thanks in advance
Yann
donny_lang
Try with Invoke-NcSystemApi like this:
$Volume = "<your volume>"
$NewSize = "<desired size>"
$Vserver = "<your SVM>"
$Request = @"
  <volume-size>
    <new-size>$NewSize</new-size>
    <volume>$Volume</volume>
  </volume-size>
Invoke-NcSystemApi -Request $Request -VserverContext $Vserver
lafoucrier
Thank You Donny, your workaround is working.
any idea why both commandlet Get-NcVolSize an Set-NcVolSize will fail in my context?
thanks
Yann
donny_lang
Glad it's working!
If I had to guess, I'd say it is a strange bug in the module for those two cmdlets.
