ONTAP Discussions
HPE HBA Card Compatability with E2812 MODEL
PhanindruduBattar
Hi,
Wanted to check if the below any of the HBA card is having compatibility to connect with E2812 model for LUNs presentation on HPE Server DL80 gen9.
HPE StoreFabric CN1100R 10GBASE-T Dual Port Converged Network Adapter N3U52A
HPE StoreFabric CN1200E 10Gb Converged Network Adapter E7Y06A
HPE StoreFabric CN1200E 10GBASE-T Dual Port Converged Network Adapter N3U51A
1 REPLY 1
elementx
1) E2812 isn't an ONTAP model.
2) The R is QLogic-based, the E's are Broadcom. I'd be surprised if any of them did *not* work. Our IMT site is down at this time so I can't check, but you could ask Support to check for you *if* the cards are listed in the Interoperability Matrix. I wouldn't use 10GBASE-T unless I already had a mixed 10/1 G switch and no budget to go with SFP ports and the more modern 25/10 G switches.
About E2800 Optional Host Interface Card(s): https://www.netapp.com/media/17090-tr4631.pdf
