ONTAP Discussions
Having problems upgrading to ONTAP 9.1
dsclassen
As per the Upgrade Advisor I am attempting to retrieve the new image file
netapp1::> cluster image package get -url http://mywebserver.com/netapp/91_q_image.tgz
Software get http://mywebserver/netapp/91_q_image.tgz started on node netapp1-01
Downloading package. This may take up to 10 minutes.
There is no update/install in progress
Status of most recent operation:
Run Status: Working
Exit Status: Success
Phase: Download
Exit Message:
Processing Package.
Process package failed.
Error: command failed: Error in processing the package, make sure the package version and URL are correct.
That's it.
Not really sure what to try next.
Any help or advice would be appreciated.
5 REPLIES 5
robinpeter
Make sure your "mywebserver.com" is reachable from netapp
you can use "network ping" command to make sure its reachable from cluster. (cluster shell)
if you dont have a HTTP server you can use "hfs http server) (http://www.rejetto.com/hfs/?f=dl)
its a self exceutable.. easiest way to setup a http server.
I'm actually in the middle of an upgrade..
this is what i use.
system image get -node * -package http://172.17.69.112/NetApp/91P1_q_image.tgz
system image update -node node-01 -package 91P1_q_image.tgz -setdefault true
system image update -node node-02 -package 91P1_q_image.tgz -setdefault true
then takeover giveback one by one..
thanks,
Robin.
b-phillips
Are you performing a rolling upgrade?
I am having the same issues where system image package get works, but when running cluster image pacakge get, it results in the same "error in processing the package"
"system image package show" shows the image on both nodes, but "CLUSTER image package show-repository" says its empty.
Can I still do an uninterrupted upgrade?
Thanks
Brian
SeanHatfield
Also wget the url, and verify you get the tgz file back and not some html.  Test that the tgz is valid.  The console output looks like it connected to the server but didn't get a valid archive.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
paulstringfellow
I would check that download package if i was you... could be a corrupt download, if it's finding the server and trying to pull the package but can't process it... maybe download again and see if that's any better.
liuh
hi
You need to make sure that your version package is correct and your network is fine, hopefully my command can help you
system image update -node netapp1-01 -package 9.1P20_q_nodar image.tgz -setdefault true
