ONTAP Discussions
Hot Unplug Shelves but need to move disks first - HELP!
chris_hague
Hello,
I need to move all my SATA shelves from our 7 mode system to CDOT. However, we do not have enough swing kit to do both 7 mode controllers aggr's at once.
So, I want to migrate all data from 1 filer's aggr and then destroy that aggr, hot unplug the shelf and then rinse and repeat.
BUT,
2 of the SATA shelves have 12 disks each assigned to each controller.
So,
Is there a way to move the disks between controllers \ aggr's.
e.g. remove disk 1 from node 1 aggr 1 then remove ownership and assign to node 2. Whilst simultaneously removing disk 1 from node 2 aggr 1
Is it the disk replace command? or is there an easier way?
2 REPLIES 2
prsmith
You could shut down the 7-mode controllers and swap disks between shelves so that one shelf has the disks owned by controller 1 and the other shelf has the disks owned by controller 2, then restarting the systems.  This would require an outage but would be quicker than moving disks while the systems are running.
colsen
Definitely in the "painful and slow" category, you could do what you're talking about by converting data disks to hot spares (one each from each aggregate - allowing time to level), remove ownership, eject, swap, own as hot spares on the opposite node.  Rinse, wash, repeat.  If these are big SATA disks you might be looking at a pretty long process.
At a high level, you'd just need the 7mode equivalents of the following commands:
https://library.netapp.com/ecmdocs/ECMP1196912/html/GUID-80FFD00E-8A18-49BC-B7D7-55A88F123686.html
Good luck....
