ONTAP Discussions
How do we know controller is running in cifs or nfs protocol?
newbeee
As per topic
5 REPLIES 5
JGPSHNTAP
7-mode or cdot.. Check the services
newbeee
i know those modes but which services should I check?
JGPSHNTAP
If you are running cdot
cifs show
nfs show
newbeee
How about 7 mode?
Renifa
In 7 mode, use” nfs show” command to check the status of the NFS service.
For CIFS you can use to command “cifs shares”  If CIFS protocol is enabled it will display all the shares however if it’s not enabled it will give you a message “CIFS not running”
Similarly if you type the command “cifs ? “ it will give you the commands associated to CIFS however if CIFS protocol is not running than it will give you a message “CIFS not running”
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
