ONTAP Discussions
NFS mount issue
VKALVEMULA
Hi
I created one volume added to vfiler
And exported the path to one of our Unix servers and gave RW access.
And my system admin cannot do any RW on that vol.
Did anyone had same type of issue before?
1 ACCEPTED SOLUTION
scottgelb
There is an rw which is to all though which might be showing it... change rw=tstbw.xxx.com to not allow write to all
23 REPLIES 23
VKALVEMULA
thx scott.. it worked.
question, can i alias all my hosts ..
i need to export the same volume to around 6 to 7 servers is there any way that i can alias them so i can use only
" tstbw,tstap,tstrw " instead of " tstbw.xxxxx.com,tstap.xxxxx.com,tstrw.xxxxx.com "
scottgelb
Excellent
Sent from my iPhone 4S
dburkland
If you mean reference each host by hostname instead of FQDN, you should be able to do that (as long as the default domain of the filer is equal to your domain)
