ONTAP Discussions
NFS mount problem for volumes in cluster ontap 8.2 p5
NOOPUR_NETAPP
From UI if I create export policy and add rules to it and assign the policy to volume,it works fine .
But when i do the same thing from APIs it does not work.
The steps of execution from APIs are:
1)Volume creation                                 -success
2) Export policy creation                         -success
3)Export rule creation in the policy                -success
4)Assign policy to volume                        -success
5)Mount of volume to the client as per rule        -Not working
But when I create volume from API and other steps from System Manager UI ,it works .
Please refer some person whom I can check on APIs and why it is not working from APIs if same process is being followed .
Let me know whether I am missing some parameter to set which gets automatically set when we create export policy from UI.
If you want I can attach the code snippet(which we are using for creating policy and assigning to volume) for your reference
1 REPLY 1
NOOPUR_NETAPP
Any news on this ? I need an urgent reply for the same .
Can someone who knows the APIs answer the questions and address the problem ?
