ONTAP Discussions
Need some help with a WFA workflow that creates a CIFS volume with snapmirror XDP replication.
bruce_breidall
running WFA 4.0, and looking at the release notes of 4.1, it appears it is not possibe to create a type XDP i.e. snapmirror extended_data_protection. I have managed to create a copy of the existing snapmirror command and am able to generate the type XDP. However, it fails on the invoke-expression of the modified powershell command. The errors shown below (note that I logged the contents of the $expression). Can anyone put me on what I have missed in creating the modified snapmirror command to include the extended_data_protection type? Be forewarned, I am not a powershell expert, but I think this has something to do with how Invoke-Expression is passinig parameters to the netapp powershell cmdlets. I also installed the latest (4.4) PSTK, running PS 4.. Thanks in advance.
08:50:13.571 INFO  [Create new CIFS volume and XDP snapmirror relationship - TEST] ***** Workflow Execution Started *****
08:50:13.587 INFO  [Create volume] ### Command 'Create volume' in 'POWER_SHELL' ###
08:50:34.853 INFO  [Create volume] Get-WfaCredentials -Host seantap01
08:50:34.869 INFO  [Create volume] Credentials successfully provided for 'seantap01'
08:50:34.900 INFO  [Create volume] Connect-Controller -Type CLUSTER -Name seantap01 -Credential System.Management.Automation.PSCredential -Vserver
08:50:34.978 INFO  [Create volume] Connect-NcController (with credentials) -Name seantap01 -Timeout 60000 -ErrorAction Stop -SSLVersion TLSv1.2
08:50:37.729 INFO  [Create volume] Connected to cluster node
08:50:37.932 INFO  [Create volume] Creating a new volume: New-NcVol -ErrorAction Stop -name XDPTEST1  -SpaceReserve none -State online -Size 1000m -VserverContext seasvm01 -Type rw -SnapshotReserve 0 -Aggregate n01_aggr1_sas900 -SecurityStyle ntfs -JunctionPath /XDPTEST1
08:50:41.416 INFO  [Create volume] FlexVol 'XDPTEST1' has been create successfully.
08:50:41.463 INFO  [Create volume] Command completed, took 27876 milliseconds
08:50:41.557 INFO  [Create CIFS share] ### Command 'Create CIFS share' in 'POWER_SHELL' ###
08:51:02.574 INFO  [Create CIFS share] Creating CIFS share: XDPTEST1at path: /XDPTEST1
08:51:02.699 INFO  [Create CIFS share] Using cached cluster connection
08:51:03.261 INFO  [Create CIFS share] Command completed, took 21704 milliseconds
08:51:03.340 INFO  [Create volume] ### Command 'Create volume' in 'POWER_SHELL' ###
08:51:24.419 INFO  [Create volume] Get-WfaCredentials -Host dalntap01
08:51:24.435 INFO  [Create volume] Credentials successfully provided for 'dalntap01'
08:51:24.450 INFO  [Create volume] Connect-Controller -Type CLUSTER -Name dalntap01 -Credential System.Management.Automation.PSCredential -Vserver
08:51:24.497 INFO  [Create volume] Connect-NcController (with credentials) -Name dalntap01 -Timeout 60000 -ErrorAction Stop -SSLVersion TLSv1.2
08:51:27.278 INFO  [Create volume] Connected to cluster node
08:51:27.825 INFO  [Create volume] Creating a new volume: New-NcVol -ErrorAction Stop -name XDPTEST1_mirror  -SpaceReserve none -State online -Size 1000m -VserverContext dalsvs01 -Type dp -SnapshotReserve 0 -Aggregate aggr6_DALNTAP01_02_SATA -SecurityStyle ntfs -JunctionPath $null
08:51:29.700 INFO  [Create volume] FlexVol 'XDPTEST1_mirror' has been create successfully.
08:51:29.747 INFO  [Create volume] Command completed, took 26407 milliseconds
08:51:29.810 INFO  [Create SnapMirror - copy] ### Command 'Create SnapMirror - copy' in 'POWER_SHELL' ###
08:51:50.655 INFO  [Create SnapMirror - copy] Using cached cluster connection
08:51:50.686 INFO  [Create SnapMirror - copy] Creating SnapMirror relationship between SEANTAP01:seasvm01/XDPTEST1 and DALNTAP01:dalsvs01/XDPTEST1_mirror
08:51:50.717 INFO  [Create SnapMirror - copy] Expression Contents passed from PS - New-NcSnapmirror  -ErrorAction Stop -SourceCluster SEANTAP01 -DestinationCluster DALNTAP01 -SourceVserver seasvm01 -DestinationVserver dalsvs01 -SourceVolume XDPTEST1 -DestinationVolume XDPTEST1_mirror -Type xdp -Schedule '5min' -Policy 'mirror-vault-compress'
08:51:51.702 ERROR  [Create SnapMirror - copy] Invalid value specified for "relationship-type" element within "snapmirror-create": "xdp".
08:51:51.780 ERROR  [Create SnapMirror - copy] Command failed for Workflow 'Create new CIFS volume and XDP snapmirror relationship - TEST' with error : Invalid value specified for "relationship-type" element within "snapmirror-create": "xdp".
08:51:51.780 INFO  [Create SnapMirror - copy] ***** Workflow Execution Failed *****
1 ACCEPTED SOLUTION
bruce_breidall
The issue is how netapp has confused the terminology through their evolution of software releases.
XDP (Extended data protection) is the same as vault, so try specifying "vault" as the snapmirror type...
3 REPLIES 3
DavidSpano
Bruce,
I am running WFA 4.2.0.0.1, 18 Feb2018 and it does not support snapmirror -type xdp either.  The Dictionary Entry for "Snapmirror Type" is of type 'Enum' in the cm_storage schema.  The Enum values need to be update to include "extended_data_protection".  There also needs to be a few lines of Power Shell added to the "Create Snapmirror" WFA Command.  I'm hoping Netapp will provide this in a Patch update for WFA 4.2.
bruce_breidall
Vikramjeet_Singh
in my WFA version which is same as yours vault is not an option. any ideas?
