ONTAP Discussions
Ontap 8.0RC2 Snapmirror from 32bit to 64bit
allan_neo
Hi,
would like to ask if anyone tried the snapmirror features on Ontap 8.0RC2?
i'm trying to do a snapmirror test on 32bit to 64bit volume which resulted in failure.
Anybody had a work around for this?
1 REPLY 1
pascalduk
As you found out migrating data from 32 bit to 64 bit aggregate can't be done on volume level. On qtree level it is possible.
Check the following technical report, especially section 10 and 12, for more information: http://media.netapp.com/documents/tr-3786.pdf
