ONTAP Discussions
Problem with ifgrp delete in 8.1 simulator cluster
nwalker
I'm running a 2 node c-mode cluster in a simulator, NetApp release 8.1X45. There's a problem when attempting to delete a simple one port ifgroup I created earlier.
gemini::> network port ifgrp show -node gemini-01 -ifgrp a0a
Node: gemini-01
Interface Group Name: a0a
Distribution Function: ip
Create Policy: multimode
MAC Address: 02:50:56:a7:00:0d
Port Participation: full
Network Ports: e0d
Up Ports: e0d
Down Ports: -
gemini::> network port ifgrp delete -node gemini-01 -ifgrp a0a
Error: command failed: invalid operation
When attempting the same operation with System Manager 2.0 there is a com.netapp.sysmgr.client.api.NaApiFailureException error, with error message 13114. No suggested corrective action is listed. Any troubleshooting thoughts?
This generates a log entry: vifmgr.portup: A link up event was received on node gemini-01, port a0a. But not much else.
Thanks,
Nathan
1 REPLY 1
nwalker
I must be the smartest idiot online today!
Solved this by first setting advanced and then taking down the ifgroup, i.e. `net port modify -node gemini-01 -port a0a -up-admin false`. By going into advanced mode the up-admin parameter is enabled.
Success!
