ONTAP Discussions
Problems with Default IPspace even after 9.8p1
RussF
Hello,
For ONTAP select, there are ongoing issues with the Default IPspace.  Does anyone have any resolutions?
It appears that the "patch" 9.8p1 does not resolve the problem with missing Default IPspace.  After applying patch, 3 out of 4 nodes in cluster still do not have an IPspace called "Default" assigned to any interfaces.  This patch DID resolve the problem on a single node cluster, just not for a 4-node ONTAP Select cluster.
Thoughts, suggestions?
1 REPLY 1
aladd
Hello @RussF
If you have access to the cluster shell, what do you get from the following command?
::>ipspace show -instance
