ONTAP Discussions
Snapvault for MultiStore vFilers through protection manager Problem
storage_ergo
We have several MultiStore vFilers which are setup for DR using vfiler DR commands. They are replicating to a DR site at a co-location site. We want to also archive the data that is at DR by using a Protection Policy to backup the DR destination volumes using Snapvault. when I tried to set this up I got errors trying to do that backup that the the volume was read only since it is a DR destination and it could not perform the backup. Is there something that I need to change in the protection policy to get this to work ? I've done this exact scenario with volumes outside of vFilers no problem.
Any ideas ? I think it has to do with the classificatoins of the Nodes within the protection policy but I can't seem to pinpoint it.
12 REPLIES 12
scottgelb
There is no support for vfiler DR in Operations Manager, but what you are trying is outside of this... hopefully Adai or someone can reply with the reason it fails.. I assume all volumes on the target are using Volume SnapMirror (no qtrees assigned to the vFiler forcing QSM instead?).
storage_ergo
Correct, Volume SnapMirror
storage_ergo
So I tried a workaround by creating snapvault relationships to each of the vFiler DR volumes to a new volume on the same controller so that I could import them as external relationships in DFM, but I am not able to see them in DFM as external relationships. Anyone have any other ideas ?
adaikkap
Are these relationship created using the vfiler interface or pfiler(vfiler0) interface.
If its the earlier one then DFM doesnt discover.
storage_ergo
The sv relationships I created were from vfiler0, not the vfiler interface.
adaikkap
Can you run the following command on both the VSM destination filer and the SV destination filer ?
dfm host discover <filer name/Id>
storage_ergo
Do you mean that I should perform the host discover after doing SV from the command line? We let the external SV relationship run over night (24hours) so I though it would have polled by then and seen it in DFM, but I can definately try a manual discover.
adaikkap
This is because in your case you would have used the same base snapshot on the VSM destination as the source snapshot for the SV.
But when you do it using normal dataset, DFM(PM) will try to create snapshot on this volume which is readonly.
This can be over come by using Application dataset, where PM doesn't take the snapshot rather it propagates the snapshot that is registered with it.
So you will have to create an app dataset using the API or NMSDK and use the base snap shot of the VSM as the base snapshot for the sv.
PM will take care of creating snapshot on the snapvault destination.
storage_ergo
Thank you for the reply.
Can you expand on the following "create an app dataset using the API or NMSDK and use the base snap shot of the VSM as the base snapshot for the sv" ?
Is this something that is to be scripted outside of DFM ? or is it part of DFM? Or is it a different dataset type? We have only configured our dataset's to contain aggregates, but I am interested in the app dataset, as it might solve the problem for us.
adaikkap
its part of DFM.
Yes.The ones in bold makes the difference.
[root@oncommand ]# dfpm dataset list -x app_dataset
Policy:                          Back up
Description:                     test dataset
Owner:                           adai
Contact:                         adai
Volume Qtree Name Prefix:
DR Capable:                      No
Application:                     SDU
Version:                         3.2
Server:                          red hat
Requires Non Disruptive Restore: No
Node details:
   Node Name:           Primary data
   Resource Pools:
   Provisioning Policy:
   Time Zone:
   DR Capable:          No
   vFiler:
   Node Name:           Backup
   Resource Pools:      RP3, RP4
   Provisioning Policy: Dedup-Secondary Provision
   Time Zone:
   DR Capable:          No
   vFiler:
[root@oncommand ]# dfpm dataset list -x ossv_dataset
Policy:                          Vaulting of OSSV
Description:
Owner:
Contact:
DR Capable:                      No
Node details:
   Resource Pools:
   Time Zone:
   DR Capable:          No
   vFiler:
   Node Name:           Backup
   Resource Pools:      RP3
   Time Zone:
   DR Capable:          No
   vFiler:
[root@oncommand ]#
Btw were you able to discover the relationships created outside in the external relationship tab ?
Regards
adai
chaillotn
Hello Adai,
We have a similar issue in our environment (attempting snapvault managed by OnCommand 5.0.1, on CLI-made vfiler DR destinations volumes)
We were able to achieve the first part of your solution ("you will have to create an app dataset using the API or NMSDK"), by modifying the sample "dataset.pl" in the NMSDK code with following info:
my $member_application =
      NaElement->new("application-info");
   $member_application->child_add_string( "application-name", "MySnapvault" );
   $member_application->child_add_string( "application-server-name",   "MyServer" );
   $member_application->child_add_string( "application-version", "1.0.0" );
   $member_application->child_add_string( "is-application-responsible-for-primary-backup", "true");
   my $datasetcreate = NaElement->new("dataset-create");
   $datasetcreate->child_add_string( "dataset-name", $dfmval);
   $datasetcreate->child_add_string( "provisioning-policy-name-or-id", $provname);
   $datasetcreate->child_add_string( "is-application-data", "true");
$datasetcreate->child_add($member_application);
$output = $server->invoke_elem( $datasetcreate );
But we don't have any idea of how to achieve the second step, and manage PM (in fact OnCommand 5.0.1 in our case) to "use the base snap shot of the VSM as the base snapshot for the sv."
Can you give us a hint on this part?
Thank you for your help,
Regards,
Nicolas
amirm
Hi Nicolas,
In order to modify the base snapshots used by the SV you can use the API "snapvault-secondary-initiate-incremental-transfer". It has a parameter "primary-snapshot" wherein you can specify the snapshot that you would like SV to use. Perl code for the same may look like:
my $api = new NaElement('snapvault-secondary-initiate-incremental-transfer');
$api->child_add_string('primary-snapshot','NEW_BASE');
$api->child_add_string('secondary-path','/vol/sv_test_backup/qtree1');
my $xo = $s->invoke_elem($api);
I tried this by:
1. Created a SV relationship.
2. Created a new snapshot "NEW_BASE" on the primary manually ( equivalent to the base snapshot of the VSM you have) using "snap create" CLI.
3. Using above API initiated incremental transfer and provided primary-snapshot value as "NEW_BASE" i.e. the snapshot created manually in step#2.
4. For now on all SV updates will be with respect to this NEW_BASE that you provided.
For details on how to use these & other APIs and generate code automatically checkout enhanced ZExplorer Developer Interface(ZEDI) in latest NMSDK 5.0 under <NMSDK_INTALL_PATH>\zedi\zexplore.exe. For demo on ZEDI and more info please see.
Hope this helps.
Regards.
-Amir
