ONTAP Discussions
Space allocation issue with volume Snapmirrored
brunopad87
Just got some volumes mirroring to my DR with SM.
In my production environment, vol "blaze" has 10GB allocated with guarantee set to volume.
Volume                          Allocated            Used       Guarantee
blaze                                10GB           862MB          volume
In my DR environment the same volume mirrored has 147GB allocated.
blaze                               147GB           863MB            none
Anyone could explain me why space allocated in this volume is 14 times bigger than my vol in production environment, or possible causes for this to happen?
8 REPLIES 8
kjag
Hi,
Are you using Protection Manager to create the relationship? If so it creates the secondary volume of aggregate size(which is attached to secondary) with "None" space guarantee.
As the volume created with None guarantee, it will not consume space from the aggregate until actual data  is added in the volume.
-KJag
brunopad87
Hi there,
Yeah, I'm using PM to create the relationships, but take a look at these outputs.
DR-filer> df -hA
Aggregate                total       used      avail capacity
aggr0                     25TB       22TB     3557GB      87%
aggr0/.snapshot            0TB        0TB        0TB     ---%
DR-filer> aggr show_space -h
Aggregate 'aggr0'
    Total space    WAFL reserve    Snap reserve    Usable space       BSR NVLOG           A-SIS          Smtape
           28TB          2938GB             0KB            25TB             0KB            51GB             0KB
Space allocated to volumes in the aggregate
vol0                                242GB          6656MB          volume
Aggregate                       Allocated            Used           Avail
Total space                          22TB            17TB          3557GB
Snap reserve                          0KB             0KB             0KB
WAFL reserve                       2938GB           307GB          2631GB
The used space in aggr0 is the same allocated, in other words it's consuming the space.
kjag
Hi,
No.
If you see the volume details, its having "none" guarantee. Which means it will not take the space from aggregate until some data has added into it.
The used space from aggr0 might be take for some other volume.
-KJag
brunopad87
I just have 3 volumes with guarantee set to file
sybase                              563GB           554GB            file
progress                           1380GB          1369GB            file
vmwarec                            1362GB          1348GB            file
All other volumes are set to none.
kjag
Can you check the used space of none volumes?
-KJag
brunopad87
The used is space on volumes set to none are correct, it matches my production environment.
kjag
If so what is the issue?
The mirror volume created by protection manager with none guarantee is not consuming the space from Aggregate.
-Kjag
brunopad87
As I stated before and pasted the output from my DR filer, the used space on aggr0 is the same allocated.
DR-filer> df -hA
Aggregate 'aggr0'
