ONTAP Discussions
The Defference between ONTAP8 7 mode and ONTAP8 Clustor mode.
psjl_storage
Would anyone tell me the deffernces between ONTAP8 7 mode and ONTAP8 Clustor mod ?
1) Can 7 mode setep as cluser ?
2) It seems like OTNAP8 Cluster mode inherit Ontap-GX under my investigation.
If it is true, what is the Ontap GX ? how it is different fron ONTAP7.
1 REPLY 1
jacint_juhasz
hi,
ONTAP8 7 mode is what usually you get with a NetApp box. It can be installed as a cluster, if you have a HA box (active-active) with dual controllers. It countinues the line of 7.3.x and to administer is basically the same. It also can be streched between sites (Metro Cluster).
http://media.netapp.com/documents/ds-2950.pdf
The Cluster mode is a scale-out cluster built from HA pairs of controllers, where you have a global namespace and you can access you data anywhere
http://media.netapp.com/documents/ds-2951.pdf
bye,
http://tt.yyaazz.hu
