ONTAP Discussions
Volume clone split very slow
nelsonmartins
Hi,
    Last week on 03/11 I've started a volume clone split to after this, move the splited clone to another agggr. Done the split, recorded job id and after one week later it still not finished yet.
-Why is taking too long? Isn't this like a normal copy of blocks why it takes so mutch time?
-Can I move volume clone to another node (not in  the same HA), it will be to node 4 (cluster with 4 nodes) without finished this split operation?
Details:
STGFAS04::> volume clone split start -vserver san_svm04 -flexclone ESBL_CL2_vol
Warning: Are you sure you want to split clone volume ESBL_CL2_vol in Vserver san_svm04 ?
{y|n}: y
[Job 5351] Job is queued: Split ESBL_CL2_vol.
One hour later:
STGFAS04::> volume clone split show
                                Inodes              Blocks
Vserver   FlexClone      Processed      Total    Scanned    Updated % Complete
san_svm04 ESBL_CL2_vol          55      65562    1532838    1531276          0
One week later:
                                Inodes              Blocks
san_svm04 ESBL_CL2_vol         440      65562 1395338437 1217762917          0
It will never end......
This is a FAS8060 with latest version 8.3.1 GA !!!  how come?
How can I make this more FASTER??
Thanks in advance,
Nelson Martins
There's a nice workaround for this:
The problem with clone splitting is that it processes 1 inode at a time, in a serial way, so can take long time when you have a high count of inodes.
There is a cool workaround, that will have the same effect (writable copy of the volume), will consist of:
Instead of doing directly a clone of the volume and then splitting, do the following
  1. create the clone of the volume,
  2. then perform a “volume move” of the FlexClone this will create a full copy of all the data from the flexClone on a different aggregate, this is much much faster than splitting clone!
  3. Finally move back the volume to the desired aggregate
  4. ClusterTest::*> vol move start -vserver test_2 -volume vol_win_dp_clone -destination-aggregate aggrFC_node3
      (volume move start)
    Warning: Volume will no longer be a clone volume after the move and any associated space efficiency savings will be lost. Do you want to proceed? {y|n}: y
2 REPLIES 2
JamesIlderton
What version of ONTAP are you running?  Does the volume contain a LUN?  You may be running into this bug, check the link for a workaround:
http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=834509
nelsonmartins
Hi James,
  Thanks for the reply, I'm runinng the latest version 8.3.1.
      (volume move start)
