ONTAP Discussions
Volume takes much more space than expected
axsys
Hi Guys,
So I've got this volume called "volddevprod" and it's taking double of what the actual size of the data is and I hoped you guys would be able to help me out on the case.
I get that different file systems show different sizes but the actual data that is used on this volume is around 800GB and I see almost 1.5TB used. So there needs to be some kind of misconfiguration.
Below you can see some output from the general sizing / deduplication commands. I've only came across the vol status -S command and found it strange that there's deduplicated data but it's not showing up on my df -s. We do not run any snapshots on this volume but have a snapmirror on it every 30 minutes. Has anyone got an idea what this is about?
aggr show_space
Space allocated to volumes in the aggregate
volddevprod                        1797GB          1451GB          volume
df -Vg
Filesystem               total       used      avail capacity  Mounted on
/vol/volddevprod/       1787GB     1430GB      357GB      80%  /vol/volddevprod/
snap reserve               0GB        0GB        0GB       0%  /vol/volddevprod/..
vol status -S
Volume : volddevprod
      Feature                                           Used      Used%
      User Data                                        782GB        44%
      Filesystem Metadata                             1.50GB         0%
      Inodes                                          72.5MB         0%
      Deduplication                                    645GB        36%
      Snapshot Spill                                  1.29MB         0%
      Quota Metafiles                                 24.0KB         0%
      Total                                           1.39TB        80%
df -s -g
Filesystem                used      saved       %saved
/vol/volddevprod/       1430GB        0GB           0%
sis status
Path                           State      Status     Progress
/vol/volddevprod               Enabled    Idle       Idle for 13:33:32
We run Data Ontap 8.2.2P2 7-mode since late January 2015 but had the same issue on Data Ontap 8.1.2P3 7-mode already.
Thanks!
1 ACCEPTED SOLUTION
axsys
We were just helped via NetApp case. If anyone ever runs into the issue re-run sis with "sis start -s /vol/volname".
We had stale fingerprints and due to a bug in ontap 8.1.2 http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=657692 the space has never been freed. With running the above -s command sis dedup's the whole volume and all existing files again. After that the space was freed. Make sure to run that outside peak times as that operation will consume lot of system ressources.
5 REPLIES 5
paulstringfellow
have you had a look to see if there is a baseline snapmirror snapshot in place?
ekashpureff
Axsys -
As Paul mentioned, it's probably a snapshot issue.
I didn't see any 'snap list' output for the volume.
It may be SnapMirror, or any other Snapshot copies causing the space usage.
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff, Sr.
Independent NetApp Consultant http://www.linkedin.com/in/eugenekashpureff
Senior NetApp Instructor, IT Learning Solutions http://sg.itls.asia/netapp
(P.S. I appreciate 'kudos' on any helpful posts.)
axsys
Sorry guys, Thanks for the reply, been away the last 2 days!
There's a snapmirror in place. Every 30 minutes to be exact. But to my knowledge you'd clearly see that in the df -Vg in the snap reserve which is stating 0 GB.
snap list volddevprod
Volume volddevprod
working...
  %/used       %/total  date          name
  0% ( 0%)    0% ( 0%)  Feb 18 10:30  fil-01-dr(2014870175)_volddevprod.17505 (snapmirror)
axsys
*BUMP*
Anyone has any idea?
Cheers!
axsys
