ONTAP Discussions
command on 8.3 that displays power consumption and temperature of the filer
dolphhin33
HI All
I am looking for command to with give me information about controllers power consumption and temperature.
1 ACCEPTED SOLUTION
asulliva
From ClusterShell you also have the commands "system node environment sensors show" and "storage shelf show -fields temp-op-status,voltage-op-status".  More details on shelf temp sensor are available as well (such as sensor readings, etc.) using different fields in the show command.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
4 REPLIES 4
ghislanzoni
Hi,
there is a command on 7 mode useful for this case:
environment status chassis all
In Cdot you have to use this command pattern:
run -node (node name) -command environment status chassis all
Regards
Roberto
dolphhin33
thats great Roberto, let me check it.
asulliva
Andrew
ckh
Hi,
I wasn't able to obtain voltage information from DS14-Mk4-FC. Any idea how I can get the readings?
Sin1StorConCL01::> storage shelf show -fields product-id,voltage-op-status,voltage-sensor-reading
node            shelf product-id  voltage-sensor-reading            voltage-op-status
Sin1StorConCL11 2.20  DS2246      5.70,12.420,5.70,12.420           normal,normal,normal,normal
Sin1StorConCL11 2.21  DS2246      5.70,12.420,5.70,12.420           normal,normal,normal,normal
Sin1StorConCL11 3.1   DS4243      5.110,12.220,-,-,-,-,5.110,12.140 normal,normal,unknown,unknown,unknown,unknown,normal,normal
Sin1StorConCL11 3.2   DS4243      5.110,12.180,-,-,-,-,5.110,12.220 normal,normal,unknown,unknown,unknown,unknown,normal,normal
Sin1StorConCL11 3.3   DS4243      5.110,12.140,-,-,-,-,5.110,12.140 normal,normal,unknown,unknown,unknown,unknown,normal,normal
Sin1StorConCL11 4.1   DS14-Mk4-FC -                                 -
Sin1StorConCL11 4.2   DS14-Mk4-FC -                                 -
Sin1StorConCL11 4.3   DS14-Mk4-FC -                                 -
Sin1StorConCL11 4.4   DS14-Mk4-FC -                                 -
Sin1StorConCL11 4.5   DS14-Mk4-FC -                                 -
Sin1StorConCL11 4.6   DS14-Mk4-FC -                                 -
Sin1StorConCL11 5.10  DS4246      5.150,12.380,-,-,-,-,5.150,12.380 normal,normal,unknown,unknown,unknown,unknown,normal,normal
12 entries were displayed.
