ONTAP Discussions
differences between FAS2040 and FAS3210
dormelchen
Hello,
what are the differences between these two controllers.
And why should i tell our customer to buy a 3210.
And why should he / we use Ontap 8 ?
Thanks
3 REPLIES 3
roman_verysell
Most significant benefit in 3210 is an expandability. You can use a 2x PCIe ports, for example for FlashCache, 10G Ethernet, 8G FC ports or additional SAS ports. Also you can use a Metrocluster functionality, and some benefis of new software licensing scheme with 'ONTAP Essential' bundle and other 'all-inclusive' offer.
radek_kubka
Hi,
To me this is mostly about 64-bit aggregates. Whether you need them or not is a subject to a discussion - see e.g. this thread: http://communities.netapp.com/message/49508#49508.
On that note:
Be wary that certain configuration maximums are different for 2040 vs. 3210 - e.g. max 64-bit aggregate size is 30TB for the former & 50TB for the latter.
Regards,
Radek
lrhvidsten
I can give you a couple more, though I'm not sure how many are using data compression yet:
1. VAAI
http://blogs.netapp.com/virtualstorageguy/2010/07/vsphere-41-and-vstorage-apis-for-array-integration-vaai.html
http://blogs.netapp.com/virtualstorageguy/2010/07/vmware-vsphere-vaai-demo-with-netapp.html
2. Data compression:
http://blogs.netapp.com/virtualstorageguy/2010/12/introducing-data-compression-in-ontap-801.html
I'm currently on a FAS2020 platform running 7.3.x, so unfortunately have had no experience with these features.
