ONTAP Discussions
i have a pair of C800 in a metro cluster and have a logic monitor query
koopa79
I don't know if i should be asking this hear or on logic monitor.
i have a pair of C800 in a metro cluster. I've added each array in logic monitor, but i'm getting alerts on logic monitor for some volumes all ending with -mc which i believe is the standby copy of the volume on the 2nd array, but because its not in use it has a status of 4 which is unknown.
any idea if there is a way i can get logic monitor to understand them as copies and ignore them, and if they ever swap roles, ie the standby becomes the active side and visa versa, that it also knows it can ignore that as unkown status?
or is there a way i should be adding the arrays in logicmonitor as a cluster, so its aware that the volume has a active and standby side?
1 REPLY 1
koopa79
Does that mean no one connects the netapp's to logic monitor, or does my setup with volumes ending -mc not make sense?
Thanks
