ONTAP Discussions
what is the access level required on 7 mode system to initiate 7mtt migration
shrini
Hello,
What is the access level a user has to have on 7 mode system to initiate a 7mtt transition project?
I do not have root level access and below is the error I get when I run an assessment.
"Checking whether NetBIOS aliases are configured on the 7-Mode storage system 'vfiler0@XXXX'.Failed to check whether NetBIOS aliases are configured on the 7-Mode storage system 'vfiler0@XXXX'. Error Code: 13003 Reason: User XXXX does not have capability to invoke API cifs-nbalias-names-get."
1 REPLY 1
Sahana
Hi,
It maybe because 7MTT Precheck 20092 - NetBIOS aliases feature is not supported in clustered Data ONTAP 8.2.x. Refer KB 8010416
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
