ONTAP Discussions
will SCV need SanpCenter to work?
FelixZhou
looks the SCV is independent from SnapCenter. we configured SVM on VMs. will we need snapcenter to make the SCV to work?
is there any relationship between SCV and snapCenter?
Looks not to me, but NetApp document is not make it clear.
thanks,
1 ACCEPTED SOLUTION
PravinKumar
Hi Felix,
I wanted to clarify the relationship between SCV and SnapCenter, as it might seem a bit confusing at first. Yes, you are correct that SCV (SnapCenter Plug-in for VMware vSphere) and SnapCenter are indeed independent products. You don't need SnapCenter for SCV to function properly.
However, there is a specific scenario where you would need to register SCV with SnapCenter hosts. This is only necessary if you plan to perform application-over-VMDK workflows within SnapCenter. For more details check this document https://docs.netapp.com/us-en/sc-plugin-vmware-vsphere/scpivs44_register_snapcenter_plugin_vmware_vsphere_with_snapcenter_server.html.
Thanks and Regards,
Pravin Kumar
1 REPLY 1
PravinKumar
Hi Felix,
Thanks and Regards,
Pravin Kumar
