ONTAP Hardware
10gBit LACP VIFs and partner failover confiuration
cathednet
Hi,
We've got a couple 3140s, with a 10GBit LACP VIF which in turn serves dozens of VLAN interfaces. The VIF itself has no IP addresses on it.
What's the correct RC file syntax to define the partner interface and ensure failover will take place? Is it enough to configure it on the VIF itself, or on each VLAN interface?
1 REPLY 1
aborzenkov
You need to configure VLAN interfaces for failover.
