ONTAP Hardware
Repurposing an old disk shelf with for a 2040
paulreed
Just looking at a DS14 MK2 RS-1401 p/n 430-00010+B0 XYR. It has 14x 147GB 10K FC disks
Would they be compatible with a FAS2040? Is it capable of 4Gps FC?
1 ACCEPTED SOLUTION
baijulal
MK2 is 2GBps , it should work.
3 REPLIES 3
baijulal
paulreed
Thanks
net_app_admin
Hi Paul,
Appreicate if you could share with the steps such as format all the disks before create aggr etc.
Thanks,
katherine
