ONTAP Hardware
ATTO FibreBridge 7500N factory reset
not_so_funny
Is there a way to do factory reset on 7500n? got a used one and it doesn't connect with dhcp (dhcp works with same cable and another system). what will happen if i buy serial cable and it asks for password? Or is there factory reset when the power cords are pulled?
1 ACCEPTED SOLUTION
not_so_funny
Ah, great! I'm going to get a serial cable then...
Procedure
WARNING: Do not perform this action on more than one bridge at a time.
  • Disable access to the ATTO FibreBridge
    • For Fabric attached MetroCluster, disable the switchport before resetting the password
    • For stretched MetroClusters, disable the FC port before resetting the password
  • Reset the bridge configuration
    • To reset the bridge password, connect the serial cable to the bridge to access CLI (the serial port does not require a password).
    • Default baud rate is 115200.
    • From the serial command line execute
    • restoreconfiguration default
    • If the command does not ask to restart, run the following command:
    • saveconfiguration restart
    • The process of setting the bridge back to defaults implies that all settings will be reset including
      • IP address
      • configuration settings
  • Reconfigure the bridge according to the MetroCluster configuration guide (fabric/stretched)
  • Enable access to the ATTO FibreBridge
    • For Fabric attached MetroCluster, re-enable the switchport after reconfigure
    • For Fabric attached MetroCluster, re-enable the FC port after reconfigure
8 REPLIES 8
akiendl
not_so_funny
There is no solution, only:
Table of contents
  1. Applies to
  2. Description
Or is it a QR-Code-Rallye and i have to follow the hidden data in the QR-Code below Description??
akiendl
you need to log in at the top of the page.
ak.
not_so_funny
Can smb. please suggest USB to RJ45 cable? Those i've found seem to have different RJ45 pin-out.
akiendl
did you use 11520 baud rate? the bridges and new fas/aff controllers do not use 9600 any more.
ak.
not_so_funny
no, i just connected it to the switch and looked at the empty dhcp status table. i don't have any serial cable and need to buy it...
not_so_funny
I wanted to buy the cable at the attached image, but the 6500n manual says pin 1 is DSR and not CTS (whatever that means...). Will it work?
not_so_funny
Procedure
      • IP address
