ONTAP Hardware
Cisco 3750e Only has Output Drops When Connected to NetApp FAS6080
matthewsl
We have been been troubleshooting output drops on interfaces on a Cisco 3750E that connect to numerous Netapp FAS6080 filers. We use througput test devices to send data directly to a netapp and to a netapp through a Cisco 3750e switch. The switch interface generates output drops. However, the switch doesn't create output drops when the netapp is replaced with a server or a laptop. So the issue of output drops occurs when a specfiic NetApp device is sending/receiving data with a Cisco 3750E switch. Additionally, We don't have the issue with a Cisco 3750G switch. Does NetApp have something listed in the compatibility matrix or is this new?
Thanks!
Matt
8 REPLIES 8
mitchells
How does your flow control look?
matthewsl
We turned off flow control completely on the cisco interface and the netapp and
we still have the same issue. It almost seems like there is flow control though
it is turned off.  Anyway we can trick the netapp and cisco to workthrough the
flow control, if it is the issue?
mitchells
You want flow control set to full rather than none.
What's the output from ifstat -a?  That will list the negotiated flow control status on your interfaces.
Thanks,
Mitchell
kevingraham
At the same throughput levels? Which interfaces are recording drops?
matthewsl
The original design was over portchannels configured for ip not mac addresses
load balancing. However, we removed the port channels and just ran over a single
interface and got the same problematic output drops.
mitchells
I would still be interested in seeing your flow control setup.
matthewsl
The netapp admins say "i've turned off flow control". Quick question. I want to
put an ACL on the interface basically limiting ftp tcp 21/22 and bare minimum,
say block the flow control ports. What socket is used for the netapp flow
control?
mitchells
A socket happens at layer 5 of the OSI model.  Ethernet Flow Control happens at layer 2.
Flow control enables you to manage the flow of frames between two directly connected link-partners. Flow control can reduce or eliminate dropped packets due to overrun.
To achieve flow control, you can specify a flow control option that causes packets called Pause frames to be used as needed. For example, link-partner A sends a Pause On frame to link-partner B when its receive buffers are nearly full. Link-partner B suspends transmission until it receives a Pause Off frame from link-partner A or a specified timeout threshold is reached.
http://now.netapp.com/NOW/knowledge/docs/ontap/rel733/html/ontap/nag/GUID-ED84D07C-609C-44E5-AC75-6E7FF282B557.html
This sounds like what you are experiencing.  Turn on Ethernet flow control and your issue should go away.
Thanks,
Mitchell
