ONTAP Hardware
Clustered FAS2xxx - minimum disks ?
brendanheading
Hi guys,
I am looking at proposing that we purchase an additional FAS2xxx for our DR site. Since it will be used for production as well as holding Snapmirror copies, it seems appropriate to get a clustered configuration. However, we don't need a lot of disk storage so I was planning to make do with a basic installation of 12TB of built-in disks.
Am I right in speculating that this will be somewhat wasteful due to the need to assign a spare and an aggregate to each controller ? If this is true I will have to dedicate one spare plus two disks to the second controller for a RAID-4 based root volume, and one spare plus two disks for RAID-DP on the first controller leaving 6 disks out of the 12 for storage. One option, I guess, would be to have two RAID4 aggregates of five disks each and two hot spares, yielding 8 disks for data which is almost the same as I'd get with RAID-DP and a single controller.
1 ACCEPTED SOLUTION
ekashpureff
Brendan -
You're very correct. Same issues with only 14 disks on old FAS270 units.
I'm a big fan of each head having a 5 disk RAID4 aggr.
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff
[email protected]
NetApp Instructor and Independent Consultant
http://www.linkedin.com/in/eugenekashpureff
(P.S. I appreciate points for helpful or correct answers.)
2 REPLIES 2
ekashpureff
Brendan -
At your service,
[email protected]
brendanheading
Eugene, thank you. That helps a lot.
