ONTAP Hardware
Direct connect Tape Library to FAS8040
DBenderNGS
Need some guidance as I'm fairly new to NetApp.  I'm looking to purchase a Dell TL2000 Tape library to direct connect to our NetApp 8040.  The library comes with a dual port HBA SAS controller which I assume I can direct connect to a free onboard SAS port on each controller.  I've inherited this filer so not clear on the original setup but only two of the on-board SAS ports on each controller are in use (0a/0c) and each controller has an expansion card as well with two ports used (3 DS2246 shelves ea).  Can I connect the tape to one of the free onboard SAS ports (0b or 0d)?  Or should I get an additonal expansion i/o card to use specifically for the library.
Thanks all.
1 ACCEPTED SOLUTION
andris
What version of ONTAP are you on?
You can use any free SAS port (onboard or card) for attaching SAS tape drives.
I looked in IMT: http://mysupport.netapp.com/matrix/#welcome
I didn't see explicit info on Dell TL2000 being supported.
It doesn't show up in the built-in tape configuration files, either.
That said, it might "just work" - dynamically qualified.
If it doesn't, you might need to create a tape configuration file.
See: https://library.netapp.com/ecmdocs/ECMP1610206/html/GUID-AEF05EF4-F582-4E8D-ABC0-4F784AD1643F.html
Note: A SAS tape drive will only use one link of the quad-link SAS connection. That's expected behavior (if you happen to notice the other links showing "down" in any ONTAP CLI output).
2 REPLIES 2
andris
DBenderNGS
Andris,
Appreciate the info on the SAS connections.  We're running cDOT 8.2.4.  I didn't see the TL2000 listed on the compatibility list either so probably have to look at a library that is compatible with the filer.
David
